When a shock goes bad does it make a
Old Aug 12, 2013 | 09:32 AM
2003 electronblue's Avatar
2003 electronblue
Default When a shock goes bad does it make a
When a front shock goes bad does it make a constant squeaking and creaking noise?
Old Aug 12, 2013 | 09:39 AM
3boystoys's Avatar
3boystoys
Not generally, I've seen lots of failed shocks, never heard one make those noises. Probably a bushing.
Old Aug 12, 2013 | 01:07 PM
2003 electronblue
Thanks! ill take a gamble on the bushings its only a $300 job the shocks are $700 and may not be causing this noise.
Old Aug 12, 2013 | 01:13 PM
bobeast's Avatar
bobeast
A pair of sway bar bushings is $16.95 on Amazon. Replacing them is a matter of removing 2 bolts each, swapping them out and replacing the bolts. 1/2 hour job if you have ramps, including beer break.
Please tell me you aren't going to spend $300 for this.
Old Aug 12, 2013 | 01:56 PM
DooDooBear1999's Avatar
DooDooBear1999
If you can change oil, you can change sway bar bushings.
Old Aug 12, 2013 | 01:58 PM
Daddyrama31's Avatar
Daddyrama31
Old Aug 12, 2013 | 02:15 PM
PNW Vett's Avatar
PNW Vett
St. Jude Donor '13
I'll do it for $295.00!
Just kidding, really...don't spend that much to have it done. Easy job. If you are not mechanically inclined find a friend that is and buy him some beer and pizza or something. I just hate it when shops and "stealerships" do that to folks.
Old Aug 12, 2013 | 05:06 PM
Oldvetter's Avatar
Oldvetter
My front ones were squeaking, tried lubing them, did not work, replaced them, fixed.
Here is a source, make sure you get the right ones, depends on suspension.
http://www.ecklerscorvette.com/suspe...?__p=2&reset=1
Old Aug 12, 2013 | 05:51 PM
Christee's Avatar
Christee
What type noise do they make? Thump or clunking noise?
Old Aug 12, 2013 | 06:11 PM
MikeMikeWmike's Avatar
MikeMikeWmike
when my shocks started going bad they made a squeak (sounded like a seal barking) when i would hit bumps a certain way. Best way to check is to see if there is fluid leaking out.
Old Aug 12, 2013 | 06:26 PM
2003 electronblue
A steady creaking noise while driving
Old Aug 12, 2013 | 06:42 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
Like I said in your other thread. sway bar bushing are not upper control arm bushings. its 75 dollars in parts and an hours work . 1/2 hour if you have a lift.
If you don't need the bushings, and in most saes you don't. its a little grease or Teflon tape and an hours work
Old Aug 12, 2013 | 06:50 PM
Christee's Avatar
Christee
My passenger side front "clunks/groans" when going over a bump or turning
Old Aug 12, 2013 | 07:45 PM
flaagan's Avatar
flaagan
CF "Young" Senior Member
St. Jude Donor '12
Pick up some silicone grease from O'reilly's, get out the floor jack, and spend about a half hour fixing your issue!
Old Aug 13, 2013 | 08:07 AM
2003 electronblue
Does an alinement need to be done afterwards?
Old Aug 13, 2013 | 09:46 AM
Johnz02Z06's Avatar
Johnz02Z06
St. Jude Donor '14
NO you do not need an alignment if you take the sway bar off.
You would if you take the control arm off (much bigger job)
http://forums.corvetteforum.com/c5-t...-question.html
The link below shows brake pad and sway bar replacement
http://www.vetteweb.com/tech/vemp_06.../photo_11.html
Old Aug 13, 2013 | 09:55 AM
Corvette_Ed's Avatar
Corvette_Ed
About the same amount of time if you have a pair of race jacks too. I swapped out both of my sway bars, their bushings, and all four end links in a little over an hour. It's one of the easiest things to replace on the entire car.
Old Aug 13, 2013 | 05:13 PM
2003 electronblue
It seems now no im not going to spend $300 now its $600!! no one selld bushings alone only the bushings with the sway bar for $376 plus labor plus a wheel alinmemt plus tAXS...ITS KILLING ME..
Old Aug 13, 2013 | 05:24 PM
bobeast's Avatar
bobeast
Ouch!. Seriously, If someone told you they have to replace the sway bar in order to replace the bushings, YOU ARE GETTING RIPPED OFF.
These bushing are available separately on Amazon, Ecklers, MidAmerica, zip-corvette, GMPartsHouse, etc. Just order the correct size according to your suspension option.
23mm --- FE1/Base
25.4mm --- FE3/Z51 97-99
28.6mm --- FE3/Z51 00-04
30.0mm --- FE4/Z06
31.75mm --- Hotchkis
38.4mm --- GM T1
Also note, that no wheel alignment should be required when replacing the bushings.
I would also suggest reporting whoever told you that to the BBB, or someone.
To When a shock goes bad does it make a
