Help needed..flood damage
Old Aug 17, 2013 | 05:35 PM
Sonny71's Avatar
Sonny71
Oldtimer
These are from the print out that I have, sorry I don't have my Service Manuals with me.
10-PCM-102C MAF Sensor Circuit Low Frequency-A
28-TCS-U1301H Class 2 Circuit Shorted to Battery
28-TCS-U1000H
40-BCM-B0605H BCM Internal Memory Function
40-BCM-B2723H PASS Key Detection Circuit
40-BCM-B2735H PASS Key Programming Mode Active
Old Aug 17, 2013 | 07:09 PM
Phanni's Avatar
Phanni
All but the MAF error are history codes, clear them and see if they re- occur. If they don't reappear go on your merry way.
Worst case, A BCM is pretty cheap, and the wiring harness too..
<<<I'm pretty experienced with restoring a flooded car. See picture, It's been running with no codes for 2 years now. They ain't as bad as most folks would like you to believe. Damage was almost identical to yours, about three inches in the floor boards.
