I test drove a 1999, and it had a vibrating rear-view mirror. Is this common, and is this a mirror problem or an indication of a motor problem? Thank you.
If memory serves me correctly there is an old thread around on how to fix this problem. Do a search and you should find it - I would look for you but have a doc appt to leave for know. Good Luck.
All it needs is to have the screw on the mount tightened. My mirror did the same thing when I first bought my car. Now it only vibrates when I crank the stereo up and the bass gets the whole car shaking.
I tightened the bracket on the windshield when I first bought the car and it hasn't come loose since. Don't crank down on it though. Be careful it can break off.
