Brake lights not working..help
I have no brake lights. With the pedal depressed, my HMSL (high mount stop lamp) or center brake light works. The two on each side do not. My hazard lights work and turn signals work. The running lights do work- the regular tail lights that come on when the lights are turned on.
-I don't think it could be the switch on the brake pedal itself, because the center light works.
I am not sure what all fuse systems would be tied to this, but I have checked the #8 fuse (20 amp) in the passenger footwell. It is good.
I have had the hazard switch problem all these cars are prone to. The turn signals work intermittently, and occasionally don't. If I whack the dash above the hazard switch, they might start to work. Cycle the switch a few times..that might do it.
I have had trouble with my multifunction switch as well. I've actually had it apart a few times in an attempt to repair it. Right now, my brights do not even work. Sometimes when I rotate the switch to turn the low beams on, the doors do not open but the lights still come on. If I wiggle the stalk while rotating it, the lights will pop up like they are supposed to.
I know the problem is probably the multifunction switch, but it could also be the hazard switch. I have talked with TheRadioFlyer here about the hazard bypass thing, but some seem to think that this may not fix the problem (if in fact it is the hazard switch causing the brake light issue). I'm not sure why they would think this. If the factory hazard switch is prone to failure in another few months after replacement any way, why go that route?? I'd rather spend a few bucks and get the bypass.
The multifunction switch is the most expensive, so I'd like to rule out everything else before I spend the money on it.
Any other brake circuit fuses or relays to check?
Please help me figure this out. I'm about to go nuts. Not only is it embarrassing, it isn't safe and I pretty much daily drive this car.
For some reason, I seem to think that it actually replaces the factory hazard switch.
If not, I'm running factory tails, so I don't think it would be much help.
I know the factory hazard switch isn't as expensive as the multifunction switch though..., so I will do it first. I need it anyway due to the problems I have been having with my current one.
It's probably been discussed a bunch before, but what gets me is the construction of these parts. Obviously these parts are prone to going bad a lot, I just wish someone would design some aftermarket stuff that works better. I don't have time to be constantly changing parts to keep my car up and running
The crazy thing is that when I took my multifunction switch apart, my contacts had gotten so hot on the low beam side of the contacts, they actually melted the plastic underneath them. Mine was obviously not the only one to have done this. Of course, the first thing most people think of is a bad ground, but I have redone just about every one of those on my car and gotten them as good as possible. I may have missed one, but it just doesn't make sense that the switch would get so hot like that.
Here is my post from the tech thread that details what I did-
http://forums.corvetteforum.com/c5-t...ction-fix.html
If the contacts in your MFS go that hot, i'd be concerned about small wires melting their insulation. Particularly since the low voltages wires that go from the MFS go to the BCM are typically rather thin and easy to damage with excessive heat.
I then worked the switch down to the radio area where I could get some get it of an put the new one on. It was tricky getting the new switch maneuvered back into position, and a little more difficult to get the required pressure to the rear of it to push it towards me to lock it in, but I got it. Then just put the radio back in and good to go.
Turn signal issues are normally in the hazard switch (flasher unit) or the multifunction switch.
Brake light issues are normally in the hazard switch or the multifunction switch. Sometimes it can be the brake petal switch if the 3rd brake light does not work also.
If you are having brake light issues PM me with your phone number and I can help you solve your problem.
I just bought the hyper flash harnass but can return it.
I could just replace the hazard switch.
That was my first idea but I saw a thread where hyper flash solved the problem with brake light that dont work but third light does.
Oh well
So.....new hazard switch.
Should I go oem or other..
And is the center console removal radio removal method to access the switch the best way.
My tail lights go out intermittently.
Everything else works.
No leds
Playing with the switch I guess helps at times
Look at this in the interim:
http://forums.corvetteforum.com/c5-t...elocation.html
Thanks.
Since your problem seems to be intermittent I would think the multifunction switch is the source. I would guess some times just the left or right brake lights work and sometimes neither.
Removal:
http://forums.corvetteforum.com/c5-t...-a-how-to.html
Repair:
http://forums.corvetteforum.com/c5-t...f-replace.html
