handling concern
Old Aug 21, 2013 | 11:58 AM
happyfunballe's Avatar
happyfunballe
8th Gear
Default handling concern
I have my 1999 coupe for almost a year. it has 40,000 miles on it. it seems like the front end is loose and does not feel as "planted" as it should. what should i look at ? there was a spring broken that was 800 to replace, what else can be wrong?
Old Aug 21, 2013 | 01:52 PM
3sACROWD's Avatar
3sACROWD
My guess is the new spring changed your ride height and you need an alignment. I'm assuming the change in handling was immediately after the spring replacement.
Old Aug 21, 2013 | 02:09 PM
andrec10's Avatar
andrec10
Shocks are probably shot and replace the plastic end links with metal ones. Might as well as well replace the sways while you are at it!
To handling concern
