I REMOVED THE RUBBER BOOT ON RIGHT DOOR AND WAS CLEANING THE BLACK WIRE HORNESS AND FOR GOT TO DISCONNECT BATTERY. I HAD AN ARCH. nOW NONTHING LIGHTS UP OR WORKS ON THAT DOOR. CHECKED THE FUSE BOX UNDER THE HOOD. KNOW LUCK. PLEASE HELP IF YOU CAN, THANKS, WAYNE
MODEL IS 2000 VERT
fuse 33 took care of it.
Now what I really wanted to do ,was change oil sending unit,
gage is pegged out
looks real tight. how about a video link? C5
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
gage is pegged out
What I would do is relocate the sender so next time you can change it in 5 mins.
Thanks for info.
I like the O'riley you tube fix,
I don't see getting my hand in there, unless I move some things.
not sure about removing manifold.
Whats my best choice?
Originally Posted by 8VETTE7
Actually that is the PURIST's way. Any of the 3 will work unless your a purist. Then you MUST remove the intake and fight with the vacuum hoses on reinstall.
Your right, But I would rather call it the correct way rather the Purist way, I can see doing it with a socket, But I always recommend the relocation kit to save time in the future and I also think the heat from the block has an effect on the sender, Just my opinion, I would never cut a hold in any case.
Just put the oil sending unit in, it works.
I went ahead and cut the hole, I did not feel comfortable pulling the intake.Thanks everyone for the help and input.I have some thin gauge aluminum and will paint flat back on both sides,double stick tape and a little black silicone.
Thanks again and keep on posting,have a great weekend.
Instead of the double stick tape, I used 3" foil tape on the inside, with silicone underneath, taped it down flat. Painted tape first.
