Solution for keeping interior cool in parked car ?
I've had shades for the windshield in the past but always have trouble getting one the right size.
I saw this online does anybody else have something like this I saw one a little nicer that clips on to the side mirrors.
I've looked at those types of exterior covers, but have always been concerned that someone else with a Vette might like to take mine home with them !
Same issues here in AZ - - tough this time of year.
So, I ordered a cockpit cover from California Pop Tops. It should be here in a day or so and I can let you know how well it works.
See: http://www.capoptop.com/
I like that they're made from Tyvek, which is a very lightweight, breathable synthetic fabric. I ordered mine in Arctic White.
Here's a pic of the cover for a C6, which is similar to the C5.
Apparently, it does not reduce night visibility and it helps keep the heat out.
That was the one I saw the first time I looked.
Defiantly let me know how you like it.
Only thing I worry about is getting lazy and stop using it.
I plan to eventually get my dash wrapped in leather so I know it will be important to keep the sun off of it.
I have a digital IR thermometer. For the fun of it, I'll measure the interior temp without a sunshade, with my white cardboard windshield shade, and then with the CalPopTop cover.
I don't plan to use it everywhere I go. But, it'll definitely be under the cover when the car is parked while I'm working or on the weekends when I'm not driving it.
I'm pretty religious about using the windshield shade. I got into the habit years ago as a way to protect the dashboard and keep it from cracking. So, I expect that I'll be good about using this cover, too.
Kind of a happy accident. The white Tyveck came with the car stowed, forgotten, in the trunk, but I needed a fitted cover for better protection.
The white cover is now protecting the good cover, and the loop in the back that used to attach to a wind up case is now hooked around my Magniflow exhaust tips when needed. Because the top cover is so loose, it billows in the breeze, creating additional cooling while still riding in place, hooked on the pipes and the front wraparound.
I hope that explains it. Not very interesting, but I thought it worth mentioning. I get a white cover to reflect the sun, with shade and a mild breeze across the grey fitted cover. They are both rolled out and attached as one.
Probably not much more labor than the cockpit shade. I hook one mirror pocket , then go across to the other and then unroll towards both ends. Done.
The best shade comes from trees. They're built to absorb as much of the sun's rays as they can. The only problem with trees is dripping sap and dripping bird, er, um, ...stuff.
Second best is a well-insulated garage.
I have the garage, and had plans to park mine inside the garage, but unfortunately I discovered too late that the driveway is too steep on the side of the garage that's long enough for the car. So, unless I want to move 3 other cars out of the driveway to get mine out of the garage, I'm stuck outside.
The neighborhood in which I live isn't really conducive to a free-standing car-port, but that is a good option for those who are able to do it.
I'll know later on this afternoon how cool it's keeping the inside of the car.
Since the cover is designed for all models (coupe/frc/`vert) it covers the trunk lid, so no excess heat will enter the cockpit from there.
I'll know how well it works by how cool the cockpit stays and how cool the front of the metal roof frame is. Even though that part is inside the car, it always gets blazing hot by the afternoon.
The temp outside was ~95 degrees. The car sat outside in the direct sunlight from 9am to 5pm.
I checked the temperature of the trunk lid, rear window and driver's side mirror periodically throughout the day and everything under the cover was noticeably cooler than what was exposed to the sunlight.
At the end of the day, I pulled the cover off and got in, the roof's metal frame and roof locking handles were cool to the touch instead of being blazing hot. The whole interior including the inside of the trunk was equally cool.
I didn't take my IR thermometer with me today, so I can't say exactly what temperature everything was, but if I were to hazard a guess, I would say it was in the low to mid 70s.
I'll take a couple of pics of how the cover is put onto the car tomorrow and post them here. It's a little different from what their video shows.
I'll also take my thermometer with me tomorrow so I can get accurate measurements of how cool everything stays under the cover vs. what's exposed to the direct sunlight.
But, this one-day test showed me that it works as advertised and I'll be using it every day from now on. Not only does it keep the car cooler, but it will keep the interior in nicer condition than a windshield sunshade alone.
Like I said, it's different from what their installation video shows. Other than this, it's the same as what's seen in the video.
