Code PO161 02 SENSOR
Old Aug 27, 2013 | 01:01 PM
sorbet70's Avatar
sorbet70
Default Code PO161 02 SENSOR
Hello all,
Last night after work my 02 vette check engine light came on.today i pulled it with my code reader came up PO161 O2 sensor.I cleared the check engine light and its running fine.IT was raining out last night mabey something got wet.
Need opinions please thanks!!!!!!!
Old Aug 27, 2013 | 05:47 PM
sorbet70's Avatar
sorbet70
Originally Posted by 8VETTE7
You don't need a code reader to get codes on a C5.
http://www.c5forum.com/ayc/dtcdic.php
OR
In fact unless you have a very expensive reader that has the module specific to the C5 you can't see anything but standard emissions codes anyway. C5's built in reader sees ALL Corvette specific and emissions related codes.
Since you gave us no info in the post nor is there any info in your profile about the car and whether it has any mods to it, my opinion would be drive it and see if the problem reoccurs and then us the C5 capability to pull ALL the codes.
Thanks for the reply, my vette a 02 c5 A4 completely stock with 25k mi.I have an CAN OBD2 CODE READER which said it was ''02 sensor heater circut bank 2 sensor 2".
Old Aug 27, 2013 | 06:28 PM
Phanni's Avatar
Phanni
If it re occurs, then start shopping for a sensor.
Old Sep 8, 2013 | 07:00 PM
GeoZ02's Avatar
GeoZ02
Cruising
Have a code PO310 car is 02 Z06
where do I look to see what needs to be fixed
Old Sep 8, 2013 | 11:01 PM
GeoZ02's Avatar
GeoZ02
Cruising
Hit the wrong key code is PO410
To Code PO161 02 SENSOR
