[Z06] Split Duration Cams
Old Aug 29, 2013 | 02:01 PM
Hitman227's Avatar
Hitman227
Default Split Duration Cams
Do split duration cams improve the powerband for our cars? The goal is maintaining midrange, while keeping up top end power. This is for overrev mostly, including no loss of low end torque.
Old Aug 30, 2013 | 02:09 PM
Hitman227's Avatar
Hitman227
FYI, both the Gen I & Gen II LS6 cams are split duration. Next I'll show a dyno graph to itemize what this means in terms of performance driving.
Old Aug 30, 2013 | 03:59 PM
AU N EGL's Avatar
AU N EGL
Start here: http://ls1tech.com/forums/generation...cam-guide.html
Old Sep 5, 2013 | 02:59 PM
Hitman227's Avatar
Hitman227
Originally Posted by AU N EGL
Internal engine combustion theories will never implement solutions, you're treading water.
Old Sep 5, 2013 | 03:16 PM
Hitman227's Avatar
Hitman227
Here you can see professional Long Tube Headers on the LS6. Notice the irregular torque curve, which implements more top-end than midrange, including carrying revs past the factory 6500 rpm. This cam is the stock ls6 cam, specifications 204/218 with 117.5 LSA.
Old Sep 5, 2013 | 05:40 PM
All_Motor_C5LS6's Avatar
All_Motor_C5LS6
Originally Posted by ASIHRA
Here you can see professional Long Tube Headers on the LS6. Notice the irregular torque curve, which implements more top-end than midrange, including carrying revs past the factory 6500 rpm. This cam is the factory ls6 cam, specifications 204/218 with 117.5 LSA.
Old Sep 5, 2013 | 06:12 PM
zeevette's Avatar
zeevette
You really shouldn't engage this guy.
Old Sep 6, 2013 | 01:10 PM
MX621's Avatar
MX621
.... bout sums this thread up...
Old Sep 11, 2013 | 03:18 PM
Hitman227's Avatar
Hitman227
You look like you should be working at Shell with your c******* piece of s*** in my way.
Old Sep 11, 2013 | 03:22 PM
Hitman227's Avatar
Hitman227
Here is another specification that utilizes a better curve for the implementation. As you can see, low end / midrange torque is greatly improved with better power on the upper end as well.
Old Sep 13, 2013 | 06:28 PM
Hitman227's Avatar
Hitman227
For best analysis, you have to check two variables, one is the power of the cam in relation to the engine, the other is adjustability corresponding to the driving. For example, stock cams can be advanced or retarded based on the application, without having to switch out cams. This will modify the curve, depending on the motor, for the implementation. Instead custom cams can be specified as required, thus there's no necessity for advances or retards.
To Split Duration Cams
