thinking about a cam
Old Aug 31, 2013 | 01:38 PM
momo20's Avatar
momo20
Originally Posted by sfc rick
If doing the cam, then get a new harmonic balancer pinned just in case you decide to FI it later on. Search "Pinning the balancer" for info.
http://www.aacorvette.com/performanc...products_id=67
I like the ideal of pinning it to start with..should of came that way stock..i know my stealth r/t tt was pinned from the factory..but maybe that was due to the twin turbo's it came with ?
Old Aug 31, 2013 | 02:14 PM
Pozesd99''s Avatar
Pozesd99'
Usually you only need to pin the crank when u supercharge no?
Old Aug 31, 2013 | 02:20 PM
sfc rick's Avatar
sfc rick
Originally Posted by momo20
wow so everyone's that has posted videos your car's sound amazing...as far as for what I plan on using the car for..maybe some auto cross, I don't for see my self going to a blower in the future at least not on this motor, so with that said just drive the car and have fun with it, what is the main difference between a 112 lsa and a 114 lsa and so on?
112 lsa
Old Aug 31, 2013 | 02:34 PM
mtndv8's Avatar
mtndv8
Originally Posted by robert miller
The cam ARUN has he calls it , his stage 3 cam. Making great power and sounds great also. Rick has it in his motor with a ysi on the stock motor making almost 1,k rwhp with it.
Robert, Would you know the numbers for his "stage 3"?
I have a GMPP ASA cam I'm considering installing this winter looking for 380-400rwhp/rwtq through my A4. I thought about the GMPP Hot cam but from my reading and the sound clips I've heard I liked the ASA better but these are both a little older in design tech.
Now I'd like to hear more about Arun's...
FYI, reference numbers for the OP...
GMPP Hot cam: 218/228 .525 112lsa
GMPP ASA: 226/236 .525 110lsa
Good luck with your choice.
Old Aug 31, 2013 | 05:04 PM
steveovette's Avatar
steveovette
Very simplified terms the lower the number the lumpier the idle.
Generally all things being equal a 112 will idle rougher than a 114.
Just a note on the GMPP ASA cam, its not recommended for A4 equipped cars as vacuum could be an issue with the 110 LSA
Old Aug 31, 2013 | 05:28 PM
momo20's Avatar
momo20
thanks steveo for that bit of info.
Old Aug 31, 2013 | 05:48 PM
mtndv8's Avatar
mtndv8
Certainly not trying to hyjack the thread OP but would like to follow up on Steveo's comment as it does apply somewhat to your original question.
Steveo, all the reading I've done, and honestly I'm still learning, this is the first time I've read this. Could you explain what you mean? I'm not seeing a logical connection between vacuum and an A4 and 110 lsa?
Old Aug 31, 2013 | 09:14 PM
Paul 75 L82's Avatar
Paul 75 L82
Rick, sounds very good.
Old Aug 31, 2013 | 10:28 PM
sfc rick's Avatar
sfc rick
Thanks Paul!
