[Z06] Clutch replacement time...
Old Sep 1, 2013 | 10:26 AM
TXGS507's Avatar
TXGS507
Default Clutch replacement time...
So, the GF and I went on a little cruise to the Casino's last night and I believe that my LS6 is going out... Starting to slip a bit, engagement is a bit notchy, and I can smell it... you guy's know the smell.. So, the LS6 has served me well, have had it for almost 5 yrs now...
(Pre H/c/I)....
My dilemma... (choices) I have narrowed it down to the
LS7 kit, Mantic, Monster 1... Have to get this done before my Eureka Springs trip next month. B4 you guys start the "SEARCH" feedback... I have. I want your experience w these clutches. car is NOT a DD... I am only making 450/420ish to the wheels... HOWEVER, I will be building a 427 next year
So, lets hear it.... will be ordering this week.
Old Sep 1, 2013 | 10:53 AM
TXGS507's Avatar
TXGS507
Monster Level 1 w all the goodies...
http://www.coloradospeed.com/monster...v-p-18609.html
Mantic ER2
http://www.eastcoastsupercharging.co...ategory_id=252
LS7
http://forums.corvetteforum.com/c5-p...rts-house.html
Old Sep 1, 2013 | 11:01 AM
ZZOOM06's Avatar
ZZOOM06
(Pre H/c/I)....
I have been running a Textralia 0Z700 in my car for 6+ years and 20k plus miles. (around 10k with the H/C LS6 and 10k with the 416 stroker).
I have at least 100 1/4 mile passes on this clutch also and it's still going strong. I installed it with a new stock slave cylinder that is hooked up to a Tick adjustable master cylinder. It does not feel anything like the stock clutch as the pedal pressure is somewhat heavier than the LS6 clutch it replaced, but nothing that I can't handle.
It doesn't chatter on engagement but does squeak a bit on engagement when the car is cold. Proper break-in with these six puck clutches is very important. They do make a full face disc for these that most say is a bit more forgiving for street driving. When this one finally wears out, I won't hesistate to buy another one. Hope this helps.
Jimbo
Old Sep 1, 2013 | 11:08 AM
TXGS507's Avatar
TXGS507
Thank you Jimbo... 23 views, 1 comment?? come on guys... what are you running?
Old Sep 1, 2013 | 11:13 AM
Millenium Z06's Avatar
Millenium Z06
Moderator
Mines not on your list but I have a McLeod RXT twin, planned for H&C and FI. Drives almost like stock, when you let the clutch out there's very little slip and the car wants to go. Haven't had it at the track yet and it only has about 4K miles on it but it does seem to take abuse well, I like it.
I put a Tick bleeder and a new stock slave on it too but when I checked it to bleed and swap the fluid last week, it was still clear.
Old Sep 1, 2013 | 11:29 AM
TXGS507's Avatar
TXGS507
Nice Wes... come to the GTG tonight and I can drive your car... LOL.... PM me what you paid for those, if you don't mind. After crunching number there is not a whole lot of difference in pricing for each of the ones I mentioned. Clutch, flywheel, TOB,Pilot bearing,Slave, Master, ARP bolts for Flywheel, PP.... We are talking < $150 for the above mentioned kits...
Old Sep 1, 2013 | 12:05 PM
Millenium Z06
Moderator
I paid $1200 for the clutch, flywheel and GM slave and $70ish for the Tick remote bleeder.
21st installed it at no charge since they were already doing the trans (replaced under GM warranty).
Old Sep 1, 2013 | 12:06 PM
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
Old Sep 1, 2013 | 12:30 PM
onspeed's Avatar
onspeed
IMO, I would never run a factory clutch (LS7) unless you were on a tight budget.
Old Sep 1, 2013 | 01:29 PM
GARY2004Z06's Avatar
GARY2004Z06
Been running an RPS clutch for years. We run the BC2 but for your application, the half carbon street twin would be more appropriate.
http://www.turboclutch.com/Pages/RPS%20ST%20Half.htm
Great to drive on the street. Holds a lot of power. Proven on the track.
Old Sep 1, 2013 | 01:40 PM
TXGS507's Avatar
TXGS507
Thanks men... After careful consideration, reviews. I Placed an order for he Mantic ER2 w all of the goodies...
Old Sep 1, 2013 | 01:50 PM
MY03C5Z's Avatar
MY03C5Z
Why is that? Is it that bad of a clutch or is it just that the aftermarket clutches are that much better? I have heard the ls7 is 10 lbs heavier, that alone makes me not want to go with it. Im still on the original clutch at 40k, looking for a replacement down the road.
Old Sep 1, 2013 | 03:06 PM
Z06ster's Avatar
Z06ster
I went with a LS7 clutch about a year ago.... no complaints here
Old Sep 1, 2013 | 03:16 PM
racebum's Avatar
racebum
it's something like 17lbs heavier than a monster stage 1. also uses a self adjusting pressure plate which can be a cause of the sticky clutch syndrome. the monster stage 1 also uses carbon in the organic mix which makes it more resistant to fade and coming apart on slip launches
i considered an ls7 clutch but there's really nothing it has over the monster stage 1.
Old Sep 1, 2013 | 10:09 PM
onspeed's Avatar
onspeed
It's not bad, but if you have the money I think it's better to get a quality/beefy aftermarket piece, considering the amount of work that's required to change a clutch. If you're at close to stock power levels, and you're 100% sure you'll never mod, then LS7 is fine. But you don't want to put an LS7 in, then down the road you go S/C or nitrous, and then have to do a clutch job again because the LS7 can't hold the new power. Not to mention, I don't think they handle excessive clutch dumps as well as the aftermarket pieces.
To Clutch replacement time...
