Tail/brake light question
Old Sep 2, 2013 | 07:46 PM
Indyzoh6's Avatar
Indyzoh6
Default Tail/brake light question
When I hit the brakes, I noticed the inside brake lamps are brighter than the outer lamps. Both outer lights are equally dim in comparison, normal or is this a problem? Also my turn signal is either on crack or I'm just sensitive to the fact my blinker is set for 3-5 blinks per second , is this also normal?
Thanks in advance!!
