Blackwing filter install help?
Old Sep 2, 2013 | 08:30 PM
ghostrider98's Avatar
ghostrider98
Default Blackwing filter install help?
Just finished I stalling my new blackwing filter with flopac. I've read over the directions and am positive I didn't skip anything. After getting everything hooked back up the air bridge is sitting about and inch above the holes to snap it back into the radiator shroud. Is this common or have I do e something wrong?
Old Sep 2, 2013 | 11:04 PM
I have a Blackwing on mine but do not have the flopac on it. My Blackwing with the factory air bridge sits down just like the stock air intake does and does not hit the hoodliner at all. My guess is you either need to push a bit harder to seat the air bridge down on the grommets or find out if there is any other adjustment that can be made to make the air bridge sit down further.
