cam i just ordered
http://www.jegs.com/i/JEGS+Performan...00580/10002/-1
Are you sure about using stock springs, retainers, pushrods, timing chain.
I am no guru but my buddies showed me how to do the install of a Comp Cam: 228 230 580, 581 113 LSA with Patriot Gold Springs and retainers, hardened pushrods, LS2 timing chain and all the other supporting goodies.
Just wondering.
I am no guru but my buddies showed me how to do the install of a Comp Cam: 228 230 580, 581 113 LSA with Patriot II Gold Springs and retainers, hardened pushrods, LS2 timing chain and all the other supporting goodies.
Just wondering.
Still, I agree with other posters on here--go with a 228 duration & .580 lift minimum/ 232 & .600 maximum. It will run strong while still safe for stock bottom end.
If you like a little shake, also go with 112 LSA or stay with the 114 if you like it to feel stock
lifter trays
push rods
timing chain set
oil pump (sometimes)
Head work (springs, valve job, milling, etc.)
balancer (good time to replace)
new TTY bolts (most go with ARP)
gaskets
(I'm sure I've missed more)
and once it's all installed you are going to need a tune
Like I said, it's expensive to do it right and the cost of the cam itself is just one piece and it's not a place to cut corners.
I would do some research on here and see what others are using and get their feedback. I think you are about to go through a lot of work and you're not going to be happy in the end.
To make the most out of your investment I would recommend going with a cam/head package.
Good luck because this is an expensive slippery slope
http://www.engpwrsys.com/tech-notes/cam-design.html
and so does this guy (Patrick)
http://www.guerragroup.com/#!camshaft-help/c1mq5
lifter trays
push rods
timing chain set
gaskets
I think all of the above comments are in an effort to recommend that you think the cam install, parts requirements, etc., coupled with expectations all the way through before you start. Not during or after the install. Just sayin'''
Good luck with your install.
