was looking to change out the stock chrome wheels for a set of jw dish wheels with the 10.5/18 rear and having some difficulty picking out a tire. would like to throw a 315 out back but there really is only one choice in a kumho for an 18 inch rim size.
open to opinions or suggestions. if I have to use a 275, I'll probably just end up keeping the stocks on.
Reason: grammer
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
I am running 295/35/18 in the rear and 265/35/18 in the front in Bridgestone Potenza 760 Sport and really like them, It seems that maybe a 315 is just a bit much for a 10 inch wheel.
I installed 265/18 in front and 305/19 in the rear. My rear wheels are 10.5" wide. It was highly suggested not to go wider then 305 with the 10.5" wheels. Am very happy with the setup. The offset is perfect.
Thanks for all the tips. Been trying to read reviews
Well, I have it narrowed down to 3. Liked the wide tires, but the biggest streetable Tire i can find on a 10.5 18 is the nitto 555r Dr in 305. Not sure I'd want the555r
My top 3 at the moment would be
275/40/17 fr, 295/35/18 bfg kdw all around ( cool tread, longer life very street friendly)
275/40/17 fr nitto 555, 305/35/18 nitto555r
275/40/17 fr nitto 555, 295/35/18 nitto invo
thanks for clarifying that, what set did you end up with? im about to be in the market for some rears on my speedlines and was thinking of upgrading to a 305 but its my DD so idk if that is going to be a wise option for me lol
well.... I had about pulled the trigger on the nittos and ended up buying a Harley instead.
probably not a huge help.
haha thats all good, but im also in the market for harleys was looking at the '14 street bob... but ill prob wait till year end sale NEXT year for the 14 to go on clearance to make room for the 2015 stock so i have some time saving up..
Well chuckie, I'm your man on this one I guess. I did exactly what you're asking and that was to get some 18x10.5 rims (standard 58mm offset) and mounted some 315/35/18s on em. What did I use? Toyo Proxes TQ street drag radial. Maybe not what you're looking for but it's an awesome tire that hooks up amazingly. You can take a look at it here. http://www.tirerack.com/tires/BigPic...odel=Proxes+TQ
Just like you, my research showed it to be almost exactly the same diameter as my stock 275s, so the stagger wasn't messed up and neither was the speedometer. I've got a few pics up here so you can see what they look like mounted. They have about 5/8" clearance from the inner wheel well and ever so slightly protrude out from the fender, about 1/2" or so. Looks aggressive w/o being dumb looking. You can see them here: http://forums.corvetteforum.com/c5-g...s-of-pics.html
After having them for about 2 weeks now, I'm very impressed with the Toyos. Got the pair from tirecrawler.com for $538 shipped. Good luck. Many tire options for our C5s.
Did a bit more back reading and saw you almost got some Nittos. That's what I had previously, some 555s. I've heard it mentioned that Toyo makes Nittos for what its worth.
been searching around for the best size to go with for a rear for the best bang... 315 seemed too wide for me i was looking more along the line of 305 but choices are so limited but after seeing your picture it didnt look too bad, is your car lowered and does it rub at all?
My car looks to be lowered but if it is, it was done by a previous owner. I've had the 98 for a couple of years and have not lowered it any. There is zero rubbing anywhere. As I stated, I've got about 5/8" clearance from the inner wheel well. I can slip my hand in between the tire and the inner wall. Another user here on CF, Blitzkrieg, is running 345s with some 12" wheels (if I remember correctly). He did remove the inner wheel well liners however, but he did not have to mini-tub the car. Do a search for him and his tire thread. Here's one to get you started. http://forums.corvetteforum.com/c5-g...e-sizes-2.html
Hmm I think u got me sold on ur set up... I currently have 295/35 kumhos right now but I wanted to go wider so naturally I thought 305 but now seeing 315 and the set u got are a steal I think I might be going this route
