check engine light
Old Sep 7, 2013 | 06:12 PM
paldogy's Avatar
paldogy
Default check engine light
I have decided to ride with the check engine light on. $200-250 repair and for what. The car runs great, mileage ok, another goverment tax as far as I am concerned, anyone else?
Old Sep 7, 2013 | 08:16 PM
Chilliwack vettes's Avatar
Chilliwack vettes
Pull the codes and report back here.
Old Sep 7, 2013 | 09:42 PM
paldogy's Avatar
paldogy
The codes were pulled; it is an o2 sensor, i'm told there are four
Old Sep 7, 2013 | 09:48 PM
red89c4's Avatar
red89c4
lets assume that it is Just a faulty O2 sensor, no real problem there. while riding around with the check engine light on something more critical to longevity of the vehicle goes bad. since the check engine light was already illuminated you would never know. the code for the o2 sensor should tell bank 1 or bank 2. if you dont want to buy new sensors you may want to remove them and clean them with carb cleaner and reinstall.
Old Sep 7, 2013 | 09:53 PM
65GGvert's Avatar
65GGvert
You can drive with the "check engine" light on, until the "fix engine" light comes on if you choose.
Old Sep 8, 2013 | 01:31 AM
Dixiecrat's Avatar
Dixiecrat
Old Sep 8, 2013 | 02:30 AM
Chilliwack vettes
I'd sooner just fix the problem than drive around with that warning message in my face. A tank of gas up here is more than the price of an $80 O2 sensor so I don't see a big deal.
Old Sep 8, 2013 | 02:36 AM
racebum's Avatar
racebum
front o2 sensors are $20 something each for a quality denso sensor via rock auto. they take all of a couple minutes to screw in
say $50 shipped and 30 minutes to jack the car up, use a 7/8 wrench and screw them in
the code will be specific to what failed. 9 times out of 10 it's the front.
hell if you're REALLY cheap i'll send you a single working oem front for shipping
Old Sep 8, 2013 | 10:05 AM
CactusCat's Avatar
CactusCat
Ummmm, I think they want you to get it fixed.
Old Sep 8, 2013 | 10:17 AM
Phanni's Avatar
Phanni
People that own/drive a Vette and are too cheap, dumb or lazy to spend a few bucks to keep them running right amaze me.
Old Sep 8, 2013 | 12:44 PM
2KFRC5's Avatar
2KFRC5
A few years back, after tracking my Vette, The CEL came on. I think it was an overheated O2 sensor. Once it cooled down and I quit pushing the car the CEL went off on it's own. It was like the next day or so.
I read somewhere, can't remember where, that if the code didn't come back, it would clear itself after so many ignition cycles. Which it appears to have done. Hasn't happened since.
Old Sep 8, 2013 | 01:45 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
The Code will tell you which O2 sensor it is, then just replace it - even a grade schooler can do that -
Just do it and stop being scared!
Thanks,Matt
Old Sep 8, 2013 | 02:31 PM
Phanni's Avatar
Phanni
Originally Posted by C5Wolfe
How did we ever survive without check engine lights, active handling, traction control, air bags, tire pressure monitoring systems etc.....? My ole "55" Chevy has been on the road and driving for 58 years and still going strong. My "99" Corvette only has 44 years to go to equal that. With all the "bells& whistles" it's got I'm sure it will!
You're 55 Chevy was designed to get 20MPG on the highway, last maybe 5 years and 100,000 miles. The new cars with all their bells and whistles are somewhat different. Do you still run bias ply tires and drum brakes on your 55? There's more than one reason restomods are so popular. Think about it.
Old Sep 8, 2013 | 07:34 PM
C5Wolfe's Avatar
C5Wolfe
Hey Phanni, I wouldn't trade my "55" for three c-5 Corvettes. My old tired "55" is probably worth 45-50 thousand dollars easy. I'm not new to Corvettes either as I've owned 18 of them over the last 50 years of driving. I like Vettes but "shoebox Chevys rule!
Old Sep 8, 2013 | 07:48 PM
baxsom's Avatar
baxsom
These are not the 50K dollar sports cars they were when new. Now they are a decade old and can be bought on the cheap.
Old Sep 8, 2013 | 09:16 PM
Phanni's Avatar
Phanni
What's your point?
I'm not 25 years old anymore either, but I still let the pros help me keep running.
Old Sep 8, 2013 | 10:20 PM
R2R's Avatar
R2R
The issue with the CEL and a bad O2 sensor is that it can ruin your CAT if the O2 allows unburnt fuel in the CAT - then the big bucks come into play along with much more work on your end. And if your state has emission tests you are not going to get around that (as my state does). Reset the code and see if it returns, but don't ignore it for long.
Old Sep 8, 2013 | 11:30 PM
racebum's Avatar
racebum
also worse mpg and hard on the rings, you build up carbon in the chamber
most ecu's default to a fixed 10:1 AFR when the 02s are unresponsive. that's probably 10mpg, maybe 12
won't take long to pay for the o2s
Old Sep 9, 2013 | 11:02 AM
3boystoys's Avatar
3boystoys
Guy is saving what? A few dollars?? He'll spend more when other things start failing (and he spends more on FUEL). Just another person that has no clue. Cars can actually WARN you of impending issues, if your FOOL enough to IGNORE the warning, do so at you peril!
To check engine light
