Lmc5 ?
Old Sep 8, 2013 | 03:07 PM
Yellow03ZO6's Avatar
Yellow03ZO6
Default Lmc5 ?
Is it a good idea to install the lmc5 module and unlocker in my 03 ZO6? I never had a problem with the column lock. I only had one recall done for the steering wheel. The steering wheel still locks and unlocks normally. I'm leaning towards getting what I need and installing it. What has everyone else done?
Old Sep 8, 2013 | 04:17 PM
Chilliwack vettes's Avatar
Chilliwack vettes
Order & install it - don't even think about it!
A friend of mine maintains his '01 religiously including a battery tender when when not driving it and just got the column lock & message 2 weeks ago. Lucky for him the 'wait 10 seconds' worked out.
It's cheap insurance/peace of mind - just do it!
Old Sep 8, 2013 | 05:51 PM
usgecko's Avatar
usgecko
St. Jude Donor '13,'14
I had no problems and installed it just to be on the safe side
Old Sep 8, 2013 | 06:13 PM
Yellow03ZO6
what vendor sells the Lmc5?
Old Sep 8, 2013 | 06:29 PM
laurent_zo6's Avatar
laurent_zo6
St. Jude Donor '15-'16-'17-'18-'19-'20-'21-'22
You can find it here: http://www.complianceparts.com/index.html
Old Sep 8, 2013 | 06:31 PM
Yellow03ZO6
Thanks guys!
Old Sep 8, 2013 | 08:28 PM
STALION's Avatar
STALION
From: ALL governments are legalized mobsters, so doesn't matter where I live :(
After getting the "column lock" a couple of times I bought it, and installed it about a month ago. If your column still locks make sure you buy the kit with unlocker and follow the instructions to a T.
Old Sep 8, 2013 | 08:52 PM
2quick98's Avatar
2quick98
just installed one yesterday 20 min tops and compliance parts was very helpful!!!! don't buy anywhere else they are awesome!!
Old Sep 8, 2013 | 10:11 PM
dood73's Avatar
dood73
Yes, get it.
My car was fine, but I installed the LMC5 anyway to prevent the problem before it ever had a chance to happen.
Old Sep 8, 2013 | 10:22 PM
laurent_zo6
Originally Posted by dood73
Yes, get it.
Can I get a clarification here. My car got the recall work done at the dealership a few years back. I believe they installed a harness and some other parts. Do I need to uninstall/remove any of these parts if I install the Lmc5?
Old Sep 8, 2013 | 10:27 PM
calvins's Avatar
calvins
Oldtimer
Taken from the sticky at the top of the forum:
Column Lock: The 1997-2000 A4s (automatics) and all M6's (manuals, with or without the factory recall done) have a dreaded column lock issue that if not resolved by the owner will most probably rear its head at some point. 2001 and later autos do *not* have the problem. The steering column will lock up and not unlock, rendering the car not able to be driven. One main cause of this is a bad or improper battery but it has occurred when that wasn't the cause as well. Beginning in 2001 model year, the automatics were changed and eliminated the problem. All the manuals have the problem.
There are two commonly accepted methods of really resolving the issue.
1) A Column Lock Bypass (CLB). Many forum vendors carry the part necessary to make a column lock problem a thing of the past. These include Corvettes of Houston, Mid-America Motorworks, etc.
2) A LMC5 Device: http://www.complianceparts.com/products.html
Here is a thread with details on the Column Lock issue but it was written prior to the advent of the LMC5 device.
http://forums.corvetteforum.com/c5-t...ky-please.html There are a lot of forum threads on the column lock issue. Using the search function should bring up a number of them for you to review and learn.
Old Sep 8, 2013 | 10:37 PM
dood73's Avatar
dood73
You should double check with Compliance Parts to be sure, but I believe you do not have to take out the previous recall trash that was installed by the dealer.
Basically I think the module fools the computer into thinking all is great, but during the install you actually disconnect the locking motor when it is in the open position.
Keep in mind that after the install, the steering wheel will not ever lock again when you turn the car off and remove the key.
Old Sep 8, 2013 | 11:04 PM
Outlawtorn's Avatar
Outlawtorn
Thanks...just bought the un locker and module
Old Sep 8, 2013 | 11:51 PM
I'd recommend you either install the LMC-5 or a column lock bypass that is available from many vendors. You may not have had any problems so far, but why take the chance.
Old Sep 9, 2013 | 12:19 AM
laurent_zo6
Thanks for the info. Will call Compliance Parts to make sure. I will keep parts in car just in case until I decide to install it.
Old Sep 9, 2013 | 01:48 AM
OneCylinder's Avatar
OneCylinder
St. Jude Donor '13
Originally Posted by 8VETTE7
If you don't mind getting stranded by either a locked column or the 2mph fuel shutoff (you will eventually) when your not close to home, then DON't install one.
If my steering wheel does not lock with the key out, does that mean that the by-pass has been installed in my '03Z? I bought it used and my steering does not lock.
Old Sep 9, 2013 | 03:53 AM
OneCylinder
St. Jude Donor '13
Thank you 8vette7, I tried it ad did hear the bzzzzz. Guess I'll go by Chevy later and try to get a GMVIS report. By the way which system is best? CLB or LMC5.
To Lmc5 ?
Old Sep 9, 2013 | 10:51 AM
outkast6991's Avatar
outkast6991
Do 2001 and up still have the issue. The quoted sticky says it was corrected.
Old Sep 9, 2013 | 06:33 PM
outkast6991
You perhaps need to read the sticky more carefully.
ALL manual transmission C5's from 97 - 2004 have the potential to experience Column Lock symptoms.
All automatic transmission C5's from 97 - 2000 have the potential to experience Column Lock symptoms.
Automatic transmission C5's from 2001 - 2004 DO NOT experience the Column Lock symptoms.
Thanks. Reading from my phone got the better of me. At least my 01 a4 seems to be exempt.
Old Sep 9, 2013 | 09:06 PM
2quick98's Avatar
2quick98
its not a matter of if but when it will happen! it is a well known issue !!! even if the recall has been done it can still happen just get a lmc5 and have peace of mind
