Forged wheel repair
Old Sep 16, 2013 | 05:49 PM
Titan22's Avatar
Titan22
Default Forged wheel repair
I picked up a set of HRE 540's recently and they need a little attention. Over all the rims ate clean with only light curb rash, my concern is a small flat spot on on rim. I'd say on a 1 to 10 is only a 1 but before mounting tires I'd like to have it right. Can a local good wheel shop repair be trusted? I'm in Houston. If they use heat will it cause any damage or weakening of the rim? Trufully I'm good with my hands and have considered trying myself but could use a little knowledge about what might to expect. Any thoughts, the average person most likle wouldn't notice it but you can see it and feel it.
Thx R
Old Sep 16, 2013 | 10:19 PM
wamara's Avatar
wamara
Cruise-In II Veteran
Isn't this a 3 piece wheel? Why not call HRE and see if they can fix it (as opposed to replace the rim half? Maybe you could take the wheel apart and just send the one half (assuming only one half is damaged)....
Old Sep 16, 2013 | 11:25 PM
Titan22's Avatar
Titan22
Called HRE, they will replace but would have to ship the wheel to them. By the time it's said and done 350- 400$. Found a place recomended on this forum here in Houston that's done lots of work on forged multiple piece wheels, ill see what they have to say tomorrow.
Old Sep 17, 2013 | 08:12 AM
Good luck. Hope the local place can fix it for you and it doesn't cost an arm and a leg.
Old Sep 17, 2013 | 11:17 AM
envyz06's Avatar
envyz06
Good luck, I had a set of HRE's sent to them and they made them perfect, one of my barrels was bent and had them replace all the bolts
To Forged wheel repair
