I just bought a '01 C5 and was wondering about how these cars are transported when they break down or have a flat. Could not find anything in the manual. Where are they hooked to pull up a ramp truck and where are they tied down? It looks like it would be better to pull them up backwards. Does anyone have any experiences with towing or hauling these cars on flat beds? It certainly would be a nightmare to damage them after having a problem on the road. Not that I expect problems but I would like to e prepared.
I started a different thread but then saw this one so will tag on here...
I have a similar scenario:
Ok, I know there's a runflat vs non-runflat "debate" and I'm not trying to restart/fuel that.
First off let me state that I do have roadside assistance and wouldn't consider cancelling it so that has no bearing on this, but what happens if you're out and happen to get a flat with non-runflats. So now you have a car that sits VERY low to start with, compound that by one corner now even lower because it's sitting on the rim. I suspect most people who are going to show up to "assist" in such a scenario aren't going to have the where-withal to resolve the situation without doing some sort of damage to the car.
I'm sure this scenario plays out more often than we hear about but where's the flaw in my thinking?
I carry a C4 jack (in case I need it) plug kit and 12v air pump. had 3 flats so far was no issue to pull over start the pump and plug tire less than 15 min. I had the tire patched from the inside later. If its a blow out and not repairable guess you would have to take your chances with a rollback.
How the heck do they tow or load these cars on flatbeds? What do they hook on? I agree that some of the tow/ramp trucks drivers you may run across out in the boondocks may not have a clue how to handle the task. I don't have GM Roadside Assistance. Is that available for older Vettes and what is the cost?
I don't have run flats and plan on carry a can of flat fixer. I had to use it once on my truck. It got me home. There definitely are a lot of pros and cons about run flats.
Have you ever tried the aerosol cans of sealer/inflator? It saved me once on my daily driver and quicker than 12v compressor.
Problem with these is that the sealant ruins the tire pressure sensors if you are running them (some don't, most do). I carry some in my dd that I elimnated runflats from. It's the Slime kit with plugs, compressor and Slime inflator/sealant that'e supposed to be friendly to modern tire pressure sensors but that remains to be seen as I've never had to use it.
In my non-runflat vette, I carry this kit:
Mercedes jack that forum member Frederick sold many of us here.
Kit which includes compressor with built in light, plug kit, misc tools, gloves, etc.
I carry it in the back, center well with a sheet of some sort to lay down to keep from getting dirty.
Word of caution on plug kits, some of the handles are one time use or half a time they break very easy and are not to easy on your hand. I got a good set from Napa and have a kit like Patches just move it to the car I am driving.
Nice setup you have, there. I am going to put a kit together.
I see you have the same CD changer I have. The seller said it was aftermarket, but after further investigation I learned it's a factory/dealer installed unit.
I have Tire Rack's "ContiKit" I bought after I switched to non-runflats in case of a tire problem.
But I do understand your concern about road assistance. What if our car just craps out and won't start or run. THEN you need a flat bed truck with a very small angled ramp.
If I ever have to call a tow truck I would be sure and tell them it's a Corvette.
We're experiencing "thread drift", so I'll re-ask OP's question a bit more directly:
Has anyone ever had their C5 towed and, if so, how did they get it up on the flatbed? The export models apparently have tow hooks on each end, but not the US model.
(Yes, I'm assuming flatbed...here in SoCal at least, the AAA emergency phone people ask what kind of car it is and have a list of the ones that can't be handled with a hook-truck. And I'm also assuming a tow situation where the car can't power itself up the ramp.)
I can answer one part of the original question, based on an "event" with my previous car: tie-down is easy, they just run a web strap around a couple of wheel spokes on all four corners. I suppose there are aftermarket wheel designs that make this more difficult, but the stock wheels almost look like they're designed with that in mind.
Had to have my old C4 towed once (faulty rad drain valve - $5 fix). I told them it was a Corvette and they sent a flatbed. The driver was equipped with extra boards to extend the ramp to clear the front end. No issues loading and the driver took great care of the car. Don't recall what he attached to the car to pull it up but he secured it with over-the-tire straps. I think most if not all the flatbed vehicles have extra boards for low cars.
I just looked under the front of my C5 and it looks like they could attach the winch cable to the skid bars. I wonder if that is the preferred point of attachment.
Looking from behind I don't see anything I would want to hook a cable to.
Sounds like you were lucky to get a skilled and considerate ramp truck driver.
That was like watching a Roadrunner cartoon... you already know that Wylie Coyote is going to slam into the side of the mountain, but you have to watch.
It's not fun to watch but I'm not sure we're seeing the whole story.
At about 1:10 or so, the tow truck driver rolls what I think is the right rear wheel back to his truck and tosses it in. The thing is, it looks like just the rim and tire, no spokes. Given that the car is facing upstream (apparently spun), you have to wonder if the far side of the car took a major hit: it may have been headed to the body shop (or junkyard) anyway.
That assembly is held on with, what, four bolts? Not sure I'd want to pull the whole weight of the car that way...lower suspension arms maybe?
The skid bars are bolted to the frame aren't they? It really would not be pulling the whole weight of the car. Just what it takes to pull it up the ramp. Four or five guys could probably push it up the ramp. I don't think I would want to pull on the suspension parts. How would you even get under there to hook on to them?
There really must be a preferred hook up spot for C5s. Someone must know the answer. Any tow/ramp truck drivers out there?
My C5 is a daily driver with 160K miles here in the North of Boston Area - I use AAA at least twice a year. Last time the side wall blew out of rear tire. When I call, the 1st thing out of my mouth is that I need a Flat bed tow. The operator will ask why, Ill tell her it a corvette, and it's always - "Not a problem sir".
I've seen it towed two different ways, and I had no problem with either. They chain the rear and the front over the heavy components and it gets tightened. But my favorite is when they secure it by using Straps that fit over the front two tires.
