black heal marks
Old Sep 23, 2013 | 02:18 PM
scott kelly's Avatar
scott kelly
1st Gear
Default black heal marks
I have black heal marks on my door sill, need some thing to get them off. it is on the plastic part of the sill
Old Sep 23, 2013 | 02:26 PM
Corvette_Ed's Avatar
Corvette_Ed
Old Sep 23, 2013 | 02:27 PM
jfernandez98's Avatar
jfernandez98
Default Mr Clean Magic Eraser
I've used the Mr. Clean magic eraser with good luck just be careful of any run off as I believe it may stain the carpet.
Old Sep 23, 2013 | 02:28 PM
Ghost Vette's Avatar
Ghost Vette
I use Mr. Clean Magic Erasers. Works great for me.
Old Sep 23, 2013 | 02:34 PM
CQRT's Avatar
CQRT
regular cleaner/wax or white enamel polishing compound will take it off too....
Old Sep 23, 2013 | 02:45 PM
Blitzkrieg's Avatar
Blitzkrieg
AKA "The CLOWN"
I have the same problem as my sill panels are oak, I've tried the magic eraser, but it does not get all of the marks out, also leaves a white residue when it dries!
Old Sep 23, 2013 | 06:12 PM
Cheech Wizard's Avatar
Cheech Wizard
When I used the Magic Eraser, it took away about 90% of the marks, but also dulled the surface of the sill.
I ended up buying a new door sill for about $60.
If you want to do that, do a Google search for "C5 Corvette door sill panel".
Old Sep 23, 2013 | 06:20 PM
LoneStarFRC's Avatar
LoneStarFRC
It's the high heel marks on my headliner I have the most trouble removing.
Old Sep 23, 2013 | 07:53 PM
El original's Avatar
El original
That's why you should be owning a vert
Old Sep 23, 2013 | 10:07 PM
I agree. The Mr. Clean product does work very well.
Old Sep 24, 2013 | 06:24 AM
Cybermind's Avatar
Cybermind
Have you tried WD40? But, before you do, you need to test it in a hidden area to ensure that it doesn't attack the plastic. It shouldn't since it's water-based. But you never know.
Old Sep 24, 2013 | 06:35 AM
cvm's Avatar
cvm
My Man !
Old Sep 24, 2013 | 05:30 PM
Ole Blaster's Avatar
Ole Blaster
I use WD40 for a lot of cleaning...even grease off my hands safely...it contains fish oil....
To black heal marks
