Radiator Drain Questions
Old Sep 26, 2013 | 06:09 PM
RHWjr's Avatar
RHWjr
Default Radiator Drain Questions
Have you had problems with the petcock breaking when opening or closing the valve? It appears to be plastic.
How important is it to get the anti-freeze to the proper mix ratio (50-50 or 70-30)? Living in an area that never freezes, on my other cars I just drain the old anti freeze through the petcock and then refill using the jug of anti-freeze and then just add water until its full. I never measured to make sure I got the right ratio.
Old Sep 26, 2013 | 06:19 PM
VETJAZZ's Avatar
VETJAZZ
I flushed mine last January. No problem with the plastic drain ****. Just be careful to turn it 1/4 turn with a screw driver to open and close. Some recommend pulling a lower hose instead - quicker drain. I think 50/50 mixture is very important. It's not only to prevent freezing, but over heating - my issue in Southern Arizona. I used distilled water to flush the old and clean everything out, then used those containers to mix the new.
Old Sep 26, 2013 | 06:58 PM
c4cruiser's Avatar
c4cruiser
A 50-50 mix of anti-freeze and water is supposed to provide the best protection against cold temps for most of the country. A 50/50 mix is good to -37 below zero. The equal mix is also supposed to provide excellent corrosion protection too. A 60-40 mix may work but going too high a percentage may actually not work well in the cooling system.
You will find that it's cheaper to buy a gallon of the concentrate than a pre-mixed gallon. A gallon of distilled water runs about a buck at any grocery store.
When doing a flush and fill, you can easily mix the Dex concentrate together with distilled water before filling the system. Just have an empty coolant jug or even a gallon milk jug (rinsed very well!!) available. Fill it halfway full of coolant and fill the rest with the water.
When I did a flush on my '02 last year, I used the petcock to drain the system and I also removed the expansion tank to completely empty it, clean it and paint the top of the tank. I also had the rear of the car about 3" higher than the front and that helped to remove a little more coolant.
Old Sep 26, 2013 | 10:51 PM
Ron222's Avatar
Ron222
Check out Post# 2 by Patches...It's what I've been doing for years..works great. Also check out Post #4. I purchased a replacement (it's actually a wing nut type) at Discount Auto for a few dollars before I drained it the first time just in case I snapped it off during the process. Needless to say I still have the replacement in my tool box from years ago. Better to be safe then sorry.
http://forums.corvetteforum.com/c5-g...cedure-c5.html
Old Sep 27, 2013 | 02:08 AM
RHWjr's Avatar
RHWjr
You guys saved me! I was just going to drain and fill with Prestone. I didn't even know about the Dexcool. I wonder how much trouble I would have caused.
Old Sep 27, 2013 | 09:13 AM
c4cruiser's Avatar
c4cruiser
If you would have put an ethylene glycol (green) antifreeze in the car and didn't completely flush out the OEM Dexcool, the two coolants would have created a sludge and caused some real cooling problems.
Dexcool has been factory fill in Corvettes since 1994. Personally, I'm not a fan of those coolants that are supposed to work in any car. Use DExcool and change it every 3-4 years.
Old Sep 27, 2013 | 12:11 PM
Ron222's Avatar
Ron222
Hey RHW,
Glad I could help and like C4 says every 3 -4 years is a good plan, that's what I do. Also when doing it you might want to consider putting in a couple 12oz bottles of Water Wetter by Redline
http://www.redlineoil.com/Products.aspx?pcid=10
I use it myself and I know a lot of folks on the forum use it as well.
By the way I located the replacement part number for the aftermarket Drain Plug should you break yours. It's made by Doorman part number 6133 and available at Advance Auto, $5.00. Check it out here's the link....
http://shop.advanceautoparts.com/web...zoneAssigned=1
Old Sep 27, 2013 | 12:16 PM
Corvette_Ed's Avatar
Corvette_Ed
I had a shop make that mistake with my 2003 Monte Carlo.
The entire cooling system had to be replaced and the top end of the engine had to be taken apart, cleaned, and had new gaskets installed after the corrosive mix ate through them.
So, just a little trouble...
Old Sep 27, 2013 | 02:37 PM
RHWjr's Avatar
RHWjr
Again, I can't say thanks enough!
Due to some health issues I've had the car stored for a time. I finally have been able to get it out and thought rather than head straight out to the road, I'd better do some maintenance.
I thought changing the coolant was a no brainer, boy was I wrong!
Thanks again!
To Radiator Drain Questions
