Can DIC Warnings Be Shutoff?
Old Sep 28, 2013 | 03:39 AM
RHWjr's Avatar
RHWjr
Default Can DIC Warnings Be Shutoff?
I just took my C5 out of storage. I'm getting three warnings (service ABS, Service Traction Control, and Service Active Steering) that rotate on the DIC.
Until I can get it repaired, is there a way to stop the warnings on the DIC? It gets very distracting.
Before I stored the car the repair cost was a little over $4,000. Now several years later Corvette Mikes is going to repair it for $750.
Old Sep 28, 2013 | 04:26 AM
Chilliwack vettes's Avatar
Chilliwack vettes
Hit 'reset' for each one. They will still come back on whenever you start your car.
Old Sep 28, 2013 | 11:53 AM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
What year is your car? If it is a 2002 I had my 2002 fixed for 150 at absfixer.
Old Sep 28, 2013 | 12:19 PM
'Shifter's Avatar
'Shifter
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17
NCM Member '09
Reach in your passenger-side door jamb, and shake the accordian-boot for your wiring harness a little, then hit reset, see if this "cures" it....
Old Sep 28, 2013 | 12:57 PM
PhysicsDude55's Avatar
PhysicsDude55
You can turn off error code warnings in HP Tuners. Any tuner would be able to disable the codes.
Probably not worth the hassle though.
Old Sep 28, 2013 | 02:21 PM
RHWjr's Avatar
RHWjr
Corvette Mikes said there is a module that is causing the problem. Evidently, Chevy doesn't make a replacement so he sends the unit out to be repaired. The process takes several days.
Old Sep 28, 2013 | 02:42 PM
Mr.Bill's Avatar
Mr.Bill
Like I said, In most cases absfixer can fix them for 150 bucks, I had mine done years ago and still working great, There are a lot of members with a 2001-04 that have used absfixer with great results. Not sure who Corvette Mike is, But for 750 vs 150, That would be an easy choice for me. What codes are you getting?
Old Sep 28, 2013 | 02:46 PM
Corvette_Ed's Avatar
Corvette_Ed
He's probably sending it to ABSFixers and charging you a $600 markup for R&R.
Old Sep 28, 2013 | 02:55 PM
Camjamsdad's Avatar
Camjamsdad
From: It's true money can't buy happiness, but it is more comfortable crying in a Corvette than on a bicyc
St. Jude Donor '13
I wanna take my car to corvette mikes.
In any event most 2001 to 2004 cars can be fixed by abs fixers for $150.
97 to 2001 cars can't be fixed by abs fixers. Chuck CoW was reporting to be able to fix the these older units, but I'm not sure what the result ended up being as far as a success rate. What I'm getting at is if Chuck can't do it corvette mike sure cant
Old Sep 28, 2013 | 02:57 PM
Corvette_Ed
Originally Posted by 8VETTE7
It is only the 1997 - 2000 for which the EBCM and SWPS are not available and those cannot be repaired even if the code IS C1214.
Chuck CoW found a way to successfully fix some '97-'00 EBCM's dependent on exactly what's wrong. Only certain situations will allow repair.
Old Sep 28, 2013 | 03:38 PM
Corvette_Ed
You might want to read his post in the last page of this thread:
http://forums.corvetteforum.com/c5-g...abs-units.html
He seems to have backed way off from his first page claims.
Plus he doesn't even specify what he can repair. Just some testing with a Tech II must be done first.
I'll stand by my statement that you can't repair 97 -2000 EBCM's. Chuck Cow or not.
I didn't see that part, thanks. I just hope mine doesn't fail any time soon.
Old Sep 28, 2013 | 10:55 PM
Corvette Mike sells and services Corvettes (mainly used ones). He has facilities in Anaheim, CA; Chicago, IL; and on the east coast. They also have a service area for repairs.
Old Sep 29, 2013 | 03:52 AM
RHWjr's Avatar
RHWjr
I'm not home this weekend but I'll check my codes when I get back.
Where is the module located that you send in? If the vendor is fixing it for $150 and the shop is charging $750, I'd like to see if I can do it myself.
Thanks for the help!
Old Sep 29, 2013 | 04:12 AM
RHWjr's Avatar
RHWjr
It makes sense that the "Service ABS" and "Service Traction Control" warnings would be caused by the module. Does it make sense that the "Service Active Steering" would be from the same failure?
I sure hope I can figure out how to remove this module myself. I don't mind paying for a guys expertise, but $600 just to remove and replace seems too high.
I also called another shop, West Coast Corvettes and they were about the same cost as Corvette Mikes.
Old Sep 29, 2013 | 11:09 AM
Ole Blaster's Avatar
Ole Blaster
I went for a cruise sat. morning thru some country roads (2 hour ride) after the cruise we all stopped for lunch,, came out cranked the car and I got the same mess. on the DIC.....drove it home...shut it off ..crossed my fingers and cranked it back ..mess was gone.. I wonder if you disconnect the battery for 15 min. and reconnect if that may reset it.... worth a try anyway.... Good Luck....
Old Sep 29, 2013 | 12:31 PM
Camjamsdad's Avatar
Camjamsdad
St. Jude Donor '13
When mine throws the message, usually after a hard corner, or being airborne, I wait till I have to stop at a light or something, then shut the car off, open the door, close the door, then restart. If I don't open and close the door the message stays on when I restart.
Old Sep 29, 2013 | 10:10 PM
RHWjr's Avatar
RHWjr
Since getting it out of storage the messages have been consistently on.
Before storing they would come on occasionally and then stay off for months.
To Can DIC Warnings Be Shutoff?
Old Sep 29, 2013 | 10:14 PM
Mr.Bill's Avatar
Mr.Bill
I am telling you give ABSFIXER a call and see if he can fix your issue, Maybe I missed it, But what were your error codes?
Mr.Bill
Old Sep 29, 2013 | 10:23 PM
RHWjr's Avatar
RHWjr
Mr Biil I plan to call ABSFixer this week. I hope I can figure out how to do this myself. $150 vs $750 is an incredible savings.
I went to the ABSFixer website but looking at the pictures I still couldn't tell where the module is or what it will take to get it out. I'm not much of a mechanic, but I'll give it a try if I can see some pictures so I don't mess up.
I'm not home so I can't check the codes -- as soon as I get back I'll check them.
I really appreciate your help and telling me about ABSFixer.
Old Sep 29, 2013 | 10:46 PM
Mr.Bill's Avatar
Mr.Bill
The unit is mounted right under the power steering reservoir, You don't remove the whole unit, Only the part where the wires connect to. And car is driveable with the unit out.
