Am I Overheating
Sorry if my reply wasn't complete for some, but if the OP was just looking for some verification or comfort level about the temps he's seeing, then that reply would have gone a long way to that with that simple test.
BOTH fans (plural) are designed to come at the same time, the only difference being whether they do so in either low-speed, or high-speed mode.
I was putting the OP a ease with his concern.. ... Those temperatures are normal for a C5. In fact temperature readings in excess of 235 are normal. Programed into the car are factory fan settings which control high and low speed fans and the on and off temperatures under certain conditions and driving speeds..
here are the factory programed fan commands.. ( I was very intimate in the development of this area.)
Depending on the model year...
For later model years:
The low speed cooling fan is commanded on when the coolant temperature reaches 108°C (226°F). It is turned off if the coolant temperature lowers to 104°C (219°F). The high speed cooling fan is commanded on when the coolant temperature reaches 113°C (235°F). It is turned off if the coolant temperature lowers to 108°C (226°F). When the A/C is on and the coolant temperature reaches 85°C (185°F), the low speed cooling fan will be turned on at vehicle speeds less than 56 kPh (35 mph).
For early model years
we first wrote the algorithms for this and the oil life monitor both were revised in 2000. Please don't ask me how I know this.Low speed fans come on at 219, high speed fans come on at 228, low speed with a/c on...
So you see, your temps are covered by programed fan settings.. which are very normal.
Bill aka ET
Last edited by savewave; Sep 30, 2013 at 03:48 PM. Reason: Edited for compliance with rules on hostile posting
However you can purchase a handheld tuner and set the FAN On/Off settings to come on at a lower temp and keep things a bit cooler - plus recommended would be a 180* thermostat - But you must set the fan settings to come on earlier or it will not help (Lower thermostat)
Thanks,Matt
This is right from the tech manual
Misprints or syntax problems can be found all throughout the Factory Service Manuals. FSM's are usually very good sources of information, but even they are not immune to error(s). Some of the copy I have read is so poor, I think grade school children wrote it and very poor proof-reading as well.
Some need to get a grip!
