Oil pressure
Old Oct 1, 2013 | 07:09 PM
AZMoon's Avatar
AZMoon
Default Oil pressure
What is too high for oil pressure? My 2001 had a cam installed before I bought it. It runs great, but the oil pressure gage pins at 80 and when I scroll through the gages button it reads my oil pressure as 130. I had the oil changed right after I bought it. Anyone have any ideas what could be the cause?
Old Oct 1, 2013 | 07:12 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
common issue...sending unit is toast
Old Oct 1, 2013 | 07:53 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
burnt toast
Old Oct 1, 2013 | 07:56 PM
LoneStarFRC's Avatar
LoneStarFRC
VERY common problem on C5 Corvettes.
Old Oct 1, 2013 | 08:15 PM
65GGvert's Avatar
65GGvert
Read post #10 #59 and #73 among about a hundred others if you search oil pressure too high.
http://forums.corvetteforum.com/c5-t...l-in-here.html
Old Oct 1, 2013 | 08:28 PM
Camjamsdad's Avatar
Camjamsdad
From: It's true money can't buy happiness, but it is more comfortable crying in a Corvette than on a bicyc
St. Jude Donor '13
What they all said. Read the sticky above. All the info is there with debates on the 3 ways to install it yourself
Old Oct 1, 2013 | 09:20 PM
Lots of info on replacement of the sensor here on the forum. If you can't find specific repair info and want to do it yourself, I have some files that might help you out. Just PM me if you would like a copy.
Old Oct 2, 2013 | 08:13 AM
oldschoolvette's Avatar
oldschoolvette
Originally Posted by Evil-Twin
burnt toast
Old Oct 2, 2013 | 09:08 AM
Corvette_Ed's Avatar
Corvette_Ed
Take it from someone who learned the hard way.
Pull the intake to replace the sending unit, and make sure you get the brass version. O'Reilly sells them (as do some other parts stores) and those that they sell come with a lifetime warranty.
Old Oct 2, 2013 | 10:11 AM
Camjamsdad's Avatar
Camjamsdad
St. Jude Donor '13
Mine only came with a 1 year warranty but we're years past that. I'm happy with my advanced discount brass sender.
Old Oct 2, 2013 | 10:35 AM
AZMoon's Avatar
AZMoon
Thanks for the info everyone! I need to remember to do a search before I post next time.
Old Oct 2, 2013 | 11:11 AM
pewter99's Avatar
pewter99
no worries...good luck with the repair
Old Oct 2, 2013 | 11:50 AM
Corvette_Ed
Originally Posted by 8VETTE7
Sensor is on the back of the engine on the drivers side behind the intake manifold. Except for purists, there is no "Correct" way to fix it.
You can remove the intake manifold.
http://forums.corvetteforum.com/1562006410-post10.html
You can cut a hole under the cowl.
http://forums.corvetteforum.com/c5-t...-air-cowl.html
You can replace it without cutting a hole or removing the intake manifold:
The third choice is how I ended up with a broken PCV hose and a vacuum leak.
Old Oct 2, 2013 | 01:00 PM
AZMoon's Avatar
AZMoon
The link for removing the intake manifold is not working.
Old Oct 2, 2013 | 01:03 PM
Camjamsdad's Avatar
Camjamsdad
St. Jude Donor '13
There is a 4th way. It costs more so it's pretty unpopular.
Old Oct 2, 2013 | 01:17 PM
LoneStarFRC
Do NOT use Teflon tape, or anything else, on the OPS threads. It relies on a crush washer for sealing.
Old Oct 12, 2013 | 04:44 PM
5.3Avalanche's Avatar
5.3Avalanche
What is the part number for the brass sensor you bought?
To Oil pressure
