adjusting a C5 convertible top
Old Oct 11, 2013 | 08:58 AM
cltaake1's Avatar
cltaake1
1st Gear
Default adjusting a C5 convertible top
Good Morning!
I am new to the forum and was hoping someone could help me find the article/directions on adjusting a C5 convertible top. The passenger window closes over the back corner of the top. I have to close the door first, then roll up the window. Could someone please help me get a copy of this article so I can correct the problem? I would appreciate it very much. Thanks and have a great day!
Old Oct 11, 2013 | 09:41 AM
kgie1217's Avatar
kgie1217
St. Jude Donor '14
Mine does the same thing on the passenger side. So, I'd be interested to see how to adjust it as well.
Old Oct 11, 2013 | 11:41 AM
srs244's Avatar
srs244
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
just my 2 cents worth, but it isn't the top (more than likely) that is the problem it is the window angle which is adjustable to insure a snug, watertight fit. just a suggestion, but try to search for window adjustment here on the forum. one of the "give aways" is to take a look at your drivers side door with the window up (door open), then do the same with the passenger side and see if it is obvious that they "lean" differently. if i remember correctly the adjustment you can make will cause the window to "tilt" more or less to better fit against the weather strip. again, i believe that is ore your problem than the top being mis adjusted. (at least it has been on my 04 convertible)
Old Oct 11, 2013 | 12:48 PM
65GGvert's Avatar
65GGvert
Not really. The more likely fix is the top adjustment if the window is overlapping the top corner when closed. Take a look at the pictures in the link supplied.
To adjusting a C5 convertible top
