Active Handling Message
Old Oct 14, 2013 | 04:48 PM
lentislee's Avatar
lentislee
Default Active Handling Message
I own a 2004 C5 convertible that has approximately 25,500 miles. I stored it for three months with a trickle charger. There were not any messages before storage.
Now I have the message, "service active handling" upon starting. Tried reset to no avail.
Suggestions please.
Thanks.
Lentis Lee
Old Oct 14, 2013 | 05:20 PM
hisbaby02's Avatar
hisbaby02
Cruising
Could be an issue with a rear wheel sensor? Boyfriend had a similar problem with his 2002. His traction control light was on.
Old Oct 14, 2013 | 05:32 PM
Macleod52's Avatar
Macleod52
Pull the codes and post them. Can't really troubleshoot w/out those codes.
Old Oct 14, 2013 | 06:10 PM
Phanni's Avatar
Phanni
EBCM to wheel sensor even steering wheel sensor.
Pull the codes, then well have something to work with.
Old Oct 14, 2013 | 06:20 PM
lentislee's Avatar
lentislee
This posting of codes gets into an area that is entirely new...thus I am learning. I followed the procedure for extracting codes and for Number 28 - TCS is as follows:
1233HC
1234H
1235H
1248H
1282H
1283H
1288H
1295H
Thanks to all who emailed that codes were needed before one could tell what was the problem.
Lentis Lee
Old Oct 15, 2013 | 05:38 AM
lentislee's Avatar
lentislee
Have posted the codes as suggested, any help?
Thanks.
Old Oct 15, 2013 | 06:18 AM
hoosiervette's Avatar
hoosiervette
St. Jude Donor '14-'15-'16
Right front wheel speed sensor circuit open or shorted. Probably need to check your connections first to make sure they are clean and fit tightly.
Old Oct 15, 2013 | 09:48 AM
lentislee's Avatar
lentislee
I have cleaned up the diagnostic codes. I still have one code that cannot be reset. It is in the category of 28TCS. The actual code is 1233HC.
Any advice?
Thanks.
Lentis
To Active Handling Message
