Help! 2003 Power windows
Take a look at this and if you Google C5 window won't work, you'll find lots more:
http://forums.corvetteforum.com/c5-t...-half-way.html
I'm beginning to think maybe the Corvette Gods are messing with me because I have not washed it in over a month.
Seriously though, as other here have said or indicated, it probably needs a window regulator replacement.
BUT, often times, a sharp blow to the sturdy part of the door panel whilst holding down/up the window control button will bring the unit back to life. And it usually stays that way for months. It also usually sticks again sometime down the road, but the sharp blow trick to the door brings it back to life.
I have a 2003 also, and I have had my passenger window stick a couple of times on me in the last 12 months. The sharp blow trick to the door panel instantly brings it back to life.
I have a new replacement window regulator sitting in the garage. Maybe I'll install it this winter.
The secret is to make sure you operate the passenger window each and every time you get in the car.
Oh, and wash it occasionally............the car I mean.
