Headlight motor
Old Oct 27, 2013 | 06:14 PM
gregbeau's Avatar
gregbeau
8th Gear
Default Headlight motor
My left head light motor opens the head light just fine, but when I turn the switch off the headlight closes but the motor makes a loud noise. The top of the motor spins as the lid closes then continues to spin and make the spinning noise after the light closes for about 30 seconds. The right light works fine. Any ideas? Thanks Green C5
Old Oct 27, 2013 | 07:40 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
The plastic gear in that motor went out, You need to do a gear replacement with a brass gear.
http://forums.corvetteforum.com/c5-g...d-on-sale.html
Old Oct 27, 2013 | 08:07 PM
MilleniumVette's Avatar
MilleniumVette
2024 C5 of the Year Finalist - Unmodified
I feel your pain. Just the other day, my right headlight wouldn't raise when I turned the lights on. After pulling the fuse and putting it back in, the motor worked just fine. Then, when I went to shut the lights off... the driver's side motor kept spinning. What are the odds of one headlight problem immediately following another? I did order gears from Rodney Dickman, so I'll be doing the replacement soon enough.
http://rodneydickman.com/catalog/pro...6af45560471ce0
Old Oct 28, 2013 | 03:52 PM
gregbeau's Avatar
gregbeau
8th Gear
Default headlight moter
Thanks for the information. Have any of you done the gear replacement in the past? How hard is it? Any special tools needed? Thanks
Old Oct 28, 2013 | 04:08 PM
Mike98SilVert's Avatar
Mike98SilVert
Active Streak: 90 Days
Follow this: http://forums.corvetteforum.com/c5-g...orialized.html
Old Oct 28, 2013 | 04:36 PM
o2bnkc's Avatar
o2bnkc
A piece of cake.
Old Oct 28, 2013 | 09:26 PM
See my comments posted in this thread:
http://forums.corvetteforum.com/c5-g...ndy-noise.html
Old Nov 5, 2013 | 09:59 PM
MilleniumVette
Just completed it Sunday, and let everything cure until Monday for the install. The whole process goes pretty easy.
To Headlight motor
