[Z06] 03 C5Z Rough Idle
Old Nov 6, 2013 | 10:51 AM
jcs44's Avatar
jcs44
Default 03 C5Z Rough Idle
Need some help with diagnosis on totally stock 03 C5Z. Was running fine as usually driving home yesterday, but when leaving a stop light, it suddenly starting making a rattling/clattering type noise and was low on power. This noise went away quickly and it smoothed out some, but now it doesn't want to idle normally. It's like it's trying to die and then catches and won't throttle up smoothly. When dowshifting to slow, the exhaust seemed noisier than normal. Once up to speed it seems sort of OK and doesn't seem to be missing. It did die once and when I tried to restart it didn't turn over and DIC showed "Check Gages". After a couple of minutes it did restart but continued the rough idle, etc. I charged the battery up last night, but that didn't help. Oh, and no lights or codes on my cheapy code tester. Any ideas? Bad fuel load?
Thanks, jcs44
