starting problem
Old Nov 9, 2013 | 01:20 PM
trail's Avatar
trail
6th Gear
Default starting problem
i have a used 2001 corvette automatic. couple weeks ago the aftermarket alarm started acting crazy. then last week the car wouldnt start. i finally got it started by holding the key in the start position for about 10 seconds. disconnected the alarm and i still have the same problem. please help thanks
Old Nov 9, 2013 | 02:04 PM
Dave68's Avatar
Dave68
If you are sure your battery is okay, your ignition key or switch may be the problem. Bill Curlee wrote a nice procedure for checking the ignition switch in the tech section. Run a search in that section.
Old Nov 10, 2013 | 03:00 PM
trail's Avatar
trail
6th Gear
cool thanks, this car is driving me nuts. i think the rear main seal is leaking too. $$$$$ that i don't have
To starting problem
