Dead, dead, dead
Old Nov 13, 2013 | 11:20 PM
psp1946's Avatar
psp1946
2nd Gear
Default Dead, dead, dead
Baby is a 2001 Automatic. She was just driven with no issues at all. Parked in the drive way. Attempted to drive 10 minutes later. turned the key ..no noise..no dash lights..no grinding...head lights don't work...absolutely nothing. Then I tried again many times in the next couple of hours,,again nothing.
Then I tried to charge the battery. Interesting the charger will not charge the battery. Symptoms...while attempting to charge the battery..the charger's lights indicate charging starting to charge ( ABOUT 4 SECONDS) then the lights on the charger indicate failure to engage charging while from underneath the frame in the area kind of underneath the the surface shrouding and in between the right front tire and the right head light comes repeated thumping as the charger attempts to engage charging
I am open to any suggestions.
T H A N K Y O U.
Old Nov 14, 2013 | 01:05 AM
dangerz's Avatar
dangerz
St. Jude Donor '09-'10
Dead battery. Take it to Autozone to have it checked.
Old Nov 14, 2013 | 01:32 AM
psp1946's Avatar
psp1946
2nd Gear
Default Dead, dead,dead
Roger remove and check the battery. will do.
However have doubts the primary problem is battery. I would have expected some prior indication of battery weakness or problem. The sudden utter total complete collapse of the electrical system.........it is just weird. I have had many experiences of weak or dead batteries. This does not fit any past experiences.
Regardless
...battery comes out tomorrow morning..thanks!
P>S>......Lov ya picture.
Old Nov 14, 2013 | 01:38 AM
dangerz's Avatar
dangerz
Ehh, sometimes drastic temperature change does that to batteries. Did it recently get cold where you're at?
To me the biggest indicator is that your charger isn't charging the battery. I had a similar symptom with my motorcycle battery and charger and it turned out to be a dead battery. Fortunately Autozone can check that for free.
Good luck :]
Old Nov 14, 2013 | 09:54 AM
Dcollins3208's Avatar
Dcollins3208
Regardless
Although I haven't had this happen in the vette yet, I can speak from experience as it happened to my truck recently. No prior indications or warning signs that the battery was going bad. Drove to the gym with no problems... came back out an hour later and it was 100% dead, no cranking, lights, nothing. Sometimes batteries just do that I guess. Dropped a new one in and she fired right up
Old Nov 14, 2013 | 10:36 AM
Radicaltimes's Avatar
Radicaltimes
Back in the old days it seemed like a battery died slowly giving you a warning . I have had a battery start a car with no problem ,go somewhere and then nothing just like your problem. It was my battery
Old Nov 14, 2013 | 10:52 AM
Lee DeRaud's Avatar
Lee DeRaud
Originally Posted by Radicaltimes
Back in the old days it seemed like a battery died slowly giving you a warning.
Depends on what you mean by "old days": I had two different Sears DieHard batteries die hard in the early '90s.
In one case I got in the car, it cranked for a second or two and then gave a loud bang: the cell on positive end had pretty much exploded, hard enough to bulge the case.
The other one went dead over about a 15-minute period...while I was parked at Sears getting something unrelated. (In the words of Dave Barry, I am not making this up.)
Both relatively new (under two years), replaced under warranty at least.
Old Nov 14, 2013 | 10:59 AM
fwrogg's Avatar
fwrogg
nope, sometimes they just die with no indication.
Old Nov 14, 2013 | 11:26 AM
paoutlaw's Avatar
paoutlaw
I had a battery blow up in my corvette. I had just driven to the race track, 150 miles, on a very hot day and stoped to buy my pit pass. Got back in the car and turned the key. BOOM! A security guard nearby thought someone was shooting at him and ducked. I called a friend who bought a battery for me on his way. I was lucky the battery was an AGM and did't make a mess. It did blow the sides of the battery off and cracked the paint on the hood. The battery had been on a Battery Tender when the car wasn't being driven. Still don't know what caused the issue because it has been trouble free for 3 years. And no I don't race my corvette, I work on race cars.
The Outlaw
Old Nov 14, 2013 | 12:16 PM
C5Txfan's Avatar
C5Txfan
The Outlaw
I also had a battery blow the side out on me back in the 70's in a '70 Chevelle. Got some gas and went to start it and 'BAM' blew one big hole in the side. Guy working in the gas station (back when they had bays to work on cars and guys put gas in the car) came out and said there was acid leaking under car. It was the old style battery with 6 caps to add water and we noticed a spark plug wire loose on one of the plugs close to battery. We guess that a spark from that when I went to start ignited some battery acid fumes and blew the side out of it !
Old Nov 14, 2013 | 01:48 PM
3boystoys's Avatar
3boystoys
It's usually a dead short between cells that takes them out like this. A piece of crust dislodges and shorts the cell out.
Old Nov 14, 2013 | 10:49 PM
Originally Posted by 8VETTE7
Sounds like an internal failure of the battery.... Pull it out and take it to a parts store for testing. They do that free at most parts places.
I've had batteries that just failed without any prior warning. It does happen.
To Dead, dead, dead
