i just disconnect neg side on battery been doing this for years no problems..
That's what the manual recommends for storage longer than 3 weeks. Since it gets to 30 below zero here, I take the battery out and put it in the basement over the winter.
I just purchased a C5 a couple of weeks ago and the PO told me to keep the battery charged and connected when I store it for the winter. He told me it would wreak havoc with the electronics. Beyond having to reprogram everything again in the spring what else could it do? definitely easier to just connect the BT and wrap it up.
I have one on every 12V vehicle I own; best thing for seldom-started vehicles ever made, IMHO. When you have millions of something in circulation, it's always possible something's going to go wrong with a certain percentage (no matter how small) of them. The same could be said of any other plug-in appliance, including that AC adapter you prolly leave your laptop plugged in to 24x7x365... it could happen to your alarm clock or your stereo receiver.
And no, none of mine are made in China ... although they're no longer assembled in the 50 states.
Wrong. The only thing you have to reprogram are the radio stations.
The owners C5 manual even recommends disconnecting the ground cable for long term storage. It's just like any other car.
Electronics last longer when they are not energized.
We asked David Scott at GM if battery disconnection was a viable option for newer Corvettes. "Actually, it is because there are circuits using power when the vehicle is "off". Without a "Battery Tender" as you mentioned, the circuits would drain a battery in about 30 - 40 days. General Motors does not require / mandate that an owner have a charger going. We have typically recommended disconnecting the battery."
With that being the case and avoiding something like what Greekmn2 discovered, I'll be removing the battery!
I've had the neg cable on my C5 disconnected many times and when it came time to reconnect the cable i never had to reprogram anything. Not even the radio stations. Who ever told you it wreaks havoc has no idea what they are talking about.
The only problem you will run into is if you have the theft lok on the radio programmed and don't know what the pass code is. Even that can be gotten around. Just do a search here. Full details on how to recover and not have to pay a dealer a cent....
I don't know how the idea that disconnecting the battery will mess up the electronics ever got started. Perhaps the battery tender manufacturers started the rumour. Do people have to reprogram their PC every time they unplug it?
Best to keep it in a dry place, up off the concrete with relatively constant temperature. In the spring when I am ready to put it back in I put the charger on it and it still shows full charge.
1) While C-Tek chargers have a good reputation, a few, just like ANY product these days, do fail. Check amazon.com reviews.
2) When you rave over a C-Tek, what model are you talking about? They make a complete line with increasing sophistication. Some may be more reliable than others.
3) A disconnected battery in your basement still looses 1% charge/month. Doesn't sound like much, but just a few percentage separates a good battery from one that is dying. It is best to recharge to max. once per month.
I don't buy that. I stored my C3 battery in the house over the winter for ten years. In the spring it would charge for about 5 minutes on a trickle charger before showing full charge and I never had a battery go bad.
I left the batteries in my 66 and 68 Mustangs over the winter in the 1980s and they would start right up in the spring and would last long past their warranty and I live where it gets to minus 30.
I have been using a Schumacher charger for the last five years... no problems. I just bought a second one (At Tractor Supply... $24). It looks pretty much like my original unit, but lighter. Probably more solid-state circuitry. Good ratings on Amazon.
It's the family business of Tony Schumacher... driver of the US Army- sponsored AA Fuel Dragster.
We are all in the same boat! I've been using these for many many winters and was SHOCKED when it happened. Just like someone posted....I was "puntzing" around in the garage and I started smelling something..thought it was a neighbor using a chemical then I saw the smoke.
I purposely purchased the "Plus" hopefully for better quality and not just going with the cheapest.
When I saw the smoke I pulled it off the C5 so fast as I was concerned about the electrical wiring on the Corvette. The tender was between the Corvette fender and the wall of the garage made of sheetrock. The tender was placed on a computer mouse pad to protect it from the garage cement floor.
Not sure what I am going to do..I have a commerical battery charger that I can charge the car battery in the Spring if it is dead.
I hope these devices have a fire prevent system inside the tender, but I don't know.
Do what the manual recommends for storing for more than 3 weeks. Unhook the ground cable.
CTEK 4.3 from DDmods....its a better model then most of resellers here carry...free cig lighter plug-in also..
Wow, always lots of mixed views on how to use battery tenders.
I make sure the charger is on the garage floor and away from the car and cover just in case it over heats.
I do the same thing. Gives you some peace of mind that at least the charge box is away from any combustibles. I just run the clamps up through from the floor and directly to the battery.
You guys that are disconnecting the negative battery cable do you have the lead acid (like the stock one) or an optima red top. Just wondering because I have an optima red top and if I don't drive mine for a couple of weeks its dead.
I have a Red Top in my car. I stick the charger on it once a week, for about 20 minutes (in the winter, that is)....
In the January 2014 issue of Hemmings Classic Car, on page 71 there is a ad for " Battery Tender" by Deltran that not only will bring your battery up to a full charge but hold that full charge indefinitely.
A cheaper and less complete method would be the $ 9.95 version at Harbor Freight, but I've found their products are the lowest quality "consumer grade" that you can get, great for very occasional use but not to be used over the long term. In any event, I would also invest in a good smoke detector, no matter what you use and as someone else mentioned, keep the unit outside the cover. This would simplify things with your insurance company if something did happen.
It should go longer than two weeks. New cars sit on the lot for months and they don't use battery tenders or start them up every couple of weeks. How old is the battery?
Just picked up this thread. I had been using a Battery Tender Plus but one day found my AC Delco battery dead along with the tender. I don't know if the battery died and took the tender with it or vice versa, either way I wasn't prepared to hook it up to the new Optima Red Top. I've been using a Numax for the last two winters and all seems ok.
