Anyone flat tow?
Old Nov 23, 2013 | 08:40 AM
JR-01's Avatar
JR-01
Originally Posted by BADBIRDCAGE
You could get freewheel hubs for the rear wheels. That means prior to every time you tow you are removing the rear wheels, installing the hubs and reinstalling the rear wheels. Then when you reach destination you are again R&R'ing the rear wheels before you can drive the car.
Additionally if you have to back up with the car attached to your motorhome you are screwed. (How would I know this?). Flat towing is/was meant for minimal distance; such as from your residence to the drag strip within 20 miles. You arrive, disconnect, R&R wheels to put your mounted drag slicks on the car, and proceed to tech inspection.
In 1982 I flat towed a 75 Camaro from NJ to San Diego, CA. Removed the driveshaft before I started and put it back in at the motel parking lot in Spring Valley. You don't have that option on a C5. Put the car on a trailer or leave it at home. No good is going to come of flat towing the car.
I see a lot of motorhomes flat towing compact cars for use when the get to Arizona or Florida for the winter. They pull them thousands of miles.
Old Nov 23, 2013 | 09:02 AM
BADBIRDCAGE's Avatar
BADBIRDCAGE
That's great. They aren't pulling C5's.
Old Nov 23, 2013 | 09:13 AM
JR-01's Avatar
JR-01
Right. Just pointing out that flat towing is not just for short distances. It's not for Corvettes either.
Old Nov 23, 2013 | 09:36 AM
BADBIRDCAGE
I sit corrected
Old Nov 23, 2013 | 11:23 AM
paoutlaw's Avatar
paoutlaw
Towing on a trailer with all 4 wheels on the trailer would be what I would recomend. If you just need to get the car home, why not rent a trailer from U-haul or similar company. I has used these services in the past and I was very satisfied. The rented trailers are also not expensive. Just remember to take some extra ramps because the C5 is very low. If a rented trailer does not work for you, I would buy one as others have suggested.
The Outlaw
Old Nov 23, 2013 | 12:04 PM
duramaxsky's Avatar
duramaxsky
This is why I prefer a trailer. You tow it where you are going set it up and use the tow vehicle any where you need to go. Plus they are cheaper to insure and do not need engine maintenance. I would not flat tow a Corvette. A trailer to haul it on would be better.
Old Nov 23, 2013 | 12:51 PM
camburger's Avatar
camburger
It's hard to imagine a C5 Vette as a flat tow attachment in back of a motorhome. It is going to suffer indignities unbecoming of such a classic beauty. With all the more suitable vehicles available for the intended purpose, it's a head scratcher as to why pick the noble Corvette...cripes even if it was a freebie why do it? Just an opinion I couldn't keep to myself...
Old Nov 23, 2013 | 03:09 PM
memmer's Avatar
memmer
I think everyone here is missing the OPs point.I believe he simply wants to know if it is possible to flat [dingy] tow for the sheer convenience of being able to park and be able to just disconnect and be able to drive off.And like others here, I haven't a clue as to how you would set up a C5 for flat towing and much less on whether it would
even be possible with the C5s stance.
Fred
Old Nov 23, 2013 | 03:41 PM
JR-01's Avatar
JR-01
Fred
I got his point, but could not imagine doing it. He would probably have to cut holes in the bumper cover and bolt or weld tow bar mounting brackets to the frame and the hitch on the motorhome would have to be lowered so the tow bar was relatively level. C5s are so low He could run into problems pulling in to gas stations or any place that has a change in elevation or bumps. It might just tear the C5 up really bad. The biggest problem I see is a Motorhome is pretty high and a Vette is really low.
Old Nov 23, 2013 | 07:26 PM
BADBIRDCAGE
So just because someone observes hundreds of people driving motorhomes flat towing compact cars to Florida and Arizona doesn't mean it is a good thing to do?
Old Nov 23, 2013 | 07:40 PM
JR-01's Avatar
JR-01
It's a terrible thing to do. It would probably destroy the C5. Just rigging the tow bar would trash the front end.
C5s are not on the list.
http://rv-roadtrips.thefuntimesguide...ome-towing.php
Old Nov 25, 2013 | 09:46 AM
toymanbob's Avatar
toymanbob
3rd Gear
I think I got my answer, thanks. As to the negative comments about the very idea, it was the same with the MR2 and the 911.
Towing has caused very little damage and having my favorite "driver" when we arrive at our stops surely beats towing a Saturn or a Jeep like most people do. If I do buy the C5 I am sure I can build the tow brackets and will share when I do. Bob
Old Nov 25, 2013 | 10:11 AM
  #33
JR-01's Avatar
JR-01
Go for it. You will probably be the first to ever do so and all of us here would love to hear about how it works out.
Old Nov 25, 2013 | 10:16 AM
  #34
CINNEMAN's Avatar
CINNEMAN
St Jude Donor '14
and be sure and take before connection to the motorhome and after a nice long tow pictures of the undercarriage for comparison!
Old Nov 25, 2013 | 11:32 AM
  #35
bobeast's Avatar
bobeast
The good/bad thing about forums, is if you wait long enough you are certain to get the answer you were hoping for
That said, best of luck and please do let us know how it works out.
Old Nov 25, 2013 | 12:32 PM
  #36
Ona mission's Avatar
Ona mission
St. Jude Donor '14
I think're right about the damage, Most people were just cringing about the idea of towing a Corvette that far. I would put a shield or at least a bra on the car for rock chip but we all face while we're on the road. Probably very little additional damage from towing it with a bar unless you're going off-road with your rig
You WILL be arriving in style
Old Nov 25, 2013 | 01:29 PM
  #37
corvettebob1's Avatar
corvettebob1
Just a little word of warning here, if you do build the tow brackets also make sure to keep a spare transmission on hand your going to need it!
On a manual you will be constantly spinning the mainshaft without any lube on the bearings.
Automatics are a bit more involved because of spinning clutch packs W/O lube.
To Anyone flat tow?
Old Nov 25, 2013 | 01:38 PM
  #38
JR-01's Avatar
JR-01
Yeah, it would be great to have your Vette with you on trips with the Motorhome.
Old Nov 25, 2013 | 04:55 PM
  #39
2ooo-C5's Avatar
2ooo-C5
Mine will not fit on the car dolly. You can use all the rams in the world but mine will not fit
in the part of the dolly were the wheels go.
Mine is lowered and the front radiator cradle, cage whatever it is called hits the car dolly
before the wheels. so the car would be riding on this cage. Adding wood blocks under the tires
would let the cage clear but then you have nothing to suck the wheels to.
It is possible the car would stay put with just the straps but this was not something I was going to
risk on my car.
I'm not saying yours wont fit, but mine wont. There are lots of variables, just something to consider.
I see lots of people tow all kinds of cars.
If you build the brackets, I wish you the best of luck.
They are correct about it having to be a manual, you would trash an automatic.
Old Nov 25, 2013 | 05:08 PM
  #40
StatmanRN's Avatar
StatmanRN
I used to be in the RV business both as a service tech and parts and service management. While this was 20 years ago not that much has changed. We set up hundreds of tow vehicles, many of which were flat towed. There was never an issue with any of the manual trans vehicles. Some automatics were set up with a Remco lube pump that worked well unless the pump failed. Now, if you have specific information re either ZF ot T56 transmission failures or problems not lubricating, please share and I will pass along to Anthony to verify. As I mentioned, he said there is enough oiling that it should not be an issue.
