Anyone flat tow?
Old Nov 22, 2013 | 01:08 PM
toymanbob's Avatar
toymanbob
3rd Gear
Default Anyone flat tow?
Hi, I'm new here, real name of Bob. I'm looking at a nice C5 with the intention of flat towing it behind my motorhome. It is a stick shift and the paint is already beat up so my question is just, can it survive? Thanks in advance for any help. Bob
Old Nov 22, 2013 | 02:06 PM
CINNEMAN's Avatar
CINNEMAN
St Jude Donor '14
Yikes.
Old Nov 22, 2013 | 02:25 PM
JR-01's Avatar
JR-01
If you don't care about it, sure. Why not? Can it survive? Maybe.
Old Nov 22, 2013 | 02:31 PM
Rob Petyo's Avatar
Rob Petyo
MotorHomes have "skirts" attached to the bumper that look like a hula skirt that protect whatever you tow.
Plenty of folks tow.
Old Nov 22, 2013 | 02:48 PM
Derf's Avatar
Derf
Have the "skirt" on my SUV (Tahoe) when I pull my boat. I still have rock chips on the trailer, none on the boat. Must protect above the trailer? We saw a really large motorhome pulling a trailer with a black C7 on board. He had a shirt plus a shield built on the front of the trailer.
Old Nov 22, 2013 | 03:13 PM
JR-01's Avatar
JR-01
Corvettes? He is talking about towing a Corvette without a trailer. Right? I see no problem towing a Corvette on a trailer behind a motorhome.
Old Nov 22, 2013 | 04:54 PM
oldschoolvette's Avatar
oldschoolvette
how / where do you plan to attach the tow bar??
or
do you mean tow on a dolly
Old Nov 22, 2013 | 05:03 PM
obnoxus's Avatar
obnoxus
mechanically .... a 6 speed yes,,,, A4,,,, no
If you can get it up the dolly ramps
Old Nov 22, 2013 | 05:05 PM
Rob Petyo's Avatar
Rob Petyo
I ASSUMED using a trailer ... from my pic below, it looks kind of hard for stuff to come up and hit the car but I guess it does.
Old Nov 22, 2013 | 05:47 PM
c4cruiser's Avatar
c4cruiser
Trying to fit some sort of towing hooks to the front of the car will be next to impossible. A dolly would be the preferable way but even then, it might be a tough job to get a C5 up on the typical tow dollies such as the ones you rent from U-Haul.
You should be able to find decent open trailers for towing in the $1000 to $1500 price range. Using a trailer affords safety and protection. Trailers will have their own brakes and that will help in braking performance of the towing vehicle. Haul a car, either flat towed or on a dolly and you have dead weight of close to two tons that the brakes on the towing vehicle has to deal with.
And with an open trailer, you will be able to see the trailer fenders in the rear view mirrors. Flat towing will cause the car to not be visible in the mirrors.
And even though you have an M6 trans, you still have get the front wheels to turn so it can follow the tow rig. That will take some effort to disconnect the locking feature in the steering column. It's bad enough to have to deal with the steering column lock issue as it is....
Old Nov 22, 2013 | 06:36 PM
JR-01's Avatar
JR-01
I always thought flat towing was using a tow bar with all four wheels on the ground. I can not imagine anyone doing that with a Vette..
Old Nov 22, 2013 | 08:22 PM
Rob Petyo's Avatar
Rob Petyo
Well, I had no idea that was the term for it. I wouldn't even think about a flat tow.
Old Nov 22, 2013 | 10:01 PM
I don't think I would try and tow a C5 without it being on some sort of trailer. Here's what my owner's manual says about the subject:
Recreational Vehicle Towing
Recreational Vehicle Towing means towing your vehicle behind another vehicle - such as behind a motorhome. The two most common types of recreational vehicle towing are known as "dinghy towing" (towing your vehicle with all four wheels on the ground) and "dolly towing" (towing your vehicle with two wheels on the ground and two wheels up on a device known as a "dolly").
Your vehicle was not designed to be towed with any of its wheels on the ground. If your vehicle must be towed, see "Towing your vehicle" earlier in this section.
Old Nov 22, 2013 | 10:20 PM
toymanbob's Avatar
toymanbob
3rd Gear
Default Flat towing, 4 down towing, pulling a toad, etc
Yes, flat towing is towing with all four wheels on the ground. You don't need to deal with a dolly or a trailer when you reach your destination, it is the most convenient method. No owners manuals stated that it was ok to tow my MR2 or, prior to that my 911 but both worked well for years and years. There has been no damage to either. My question has not really been addressed, will the transaxle survive? Thanks again, Bob
Old Nov 22, 2013 | 11:10 PM
DaDuck's Avatar
DaDuck
I am still hung up on your words that it is a nice C5 with beat up paint.
Those two terms are mutually exclusive in my mind.
Old Nov 22, 2013 | 11:11 PM
JR-01's Avatar
JR-01
Probably no one has ever done it before, so if you want to be the first to do it, let us know how it works out.
Old Nov 22, 2013 | 11:51 PM
bobeast's Avatar
bobeast
To your root question, I don't think it would hurt the transaxle. I can't say the same for your front-end though. I'd be renting a flatbed trailer were it up to me.
To Anyone flat tow?
Old Nov 23, 2013 | 07:36 AM
oldschoolvette
or just buy a trailer and be done
Old Nov 23, 2013 | 07:55 AM
StatmanRN's Avatar
StatmanRN
I asked the same question in the C4 section and got flamed for it too. I have a 95 that I am considering keeping as a "toad".
Although I have a car trailer, the point of towing four down is it is much easier and having a FWD 76 GMC, tounge weight is an issue.
Previous poster mentioned the column lock, that would be a problem on a C5 unless bypassed.
My brother in law who is shop foreman at Monster and best tranny guy I know says no mechanical issues witheither ZF or T56. GM is as always, trying to avoid liability.
Biggest issue with either is engineering a towbar mount. Youre on your own...
Old Nov 23, 2013 | 08:18 AM
BADBIRDCAGE's Avatar
BADBIRDCAGE
You could get freewheel hubs for the rear wheels. That means prior to every time you tow you are removing the rear wheels, installing the hubs and reinstalling the rear wheels. Then when you reach destination you are again R&R'ing the rear wheels before you can drive the car.
Additionally if you have to back up with the car attached to your motorhome you are screwed. (How would I know this?). Flat towing is/was meant for minimal distance; such as from your residence to the drag strip within 20 miles. You arrive, disconnect, R&R wheels to put your mounted drag slicks on the car, and proceed to tech inspection.
In 1982 I flat towed a 75 Camaro from NJ to San Diego, CA. Removed the driveshaft before I started and put it back in at the motel parking lot in Spring Valley. You don't have that option on a C5. Put the car on a trailer or leave it at home. No good is going to come of flat towing the car.
