Need help Choosing a relay
Old Dec 2, 2013 | 05:15 PM
mickey_7106's Avatar
mickey_7106
Default Need help Choosing a relay
i need help choosing the correct relay to keep my Fog lights on when i flash my high beams. i could just order a harness from radio flyer but i like building my own things when i can.
main problem is I've seen 2 designs. one has 4 wires and the other has 5? the only thing they have in common are the numbers 30,85,86,87 and 87a(for the 5th wire?) which mean nothing to me lol was hoping somebody could help me out
TIA
BTW i have ACA lights so I'm already able to keep both my high and low beams on
Old Dec 3, 2013 | 11:46 AM
dadaroo's Avatar
dadaroo
Not sure what all the numbers mean that you reference. With that said each OEM fog light uses approximately 5 amps for 10 amp total. You just need a 12 volt relay rated for 10 amps.
Old Dec 3, 2013 | 12:35 PM
3sACROWD's Avatar
3sACROWD
FYI - Most states only allow 4 white lights to be on at the same time. If you drive with your lows, highs, and fogs on, you could get a ticket. I know your intention is for flash to pass but don't know how much high beam driving you do.
What is the reason for keeping the fogs on when you flash? Are they HID and need time to fire up again?
Old Dec 3, 2013 | 12:37 PM
Dcollins3208's Avatar
Dcollins3208
Non corvette-related, but when I wired off road lights on my truck, I only used a 4 prong relay. Here is the schematic for the relay that I used when wiring my lights:
87 is to lights (accessory)
30 is to battery or power source
86 is to switch
85 is to ground
Furthermore, to find the correct amperage of the relay you will need, you take the wattage of the lights and divide by 12 volts. so, if the lights were say 55 watts each, it would be 110/12= 9.16 amp relay (10 amp relay). Hope this makes sense!!
This is the site I used with the same info that I have explained to you: http://www.therangerstation.com/tech...ry/relays.html
Old Dec 3, 2013 | 12:39 PM
pickleseimer's Avatar
pickleseimer
St. Jude Donor '12 thru '24
What you are working with in the picture is the Bosch automotive relay. Take a look at the following for the basics and scroll down to where they talk about the Bosch unit.
http://www.bcae1.com/relays.htm
Old Dec 3, 2013 | 01:39 PM
mickey_7106
thanks
its actually federal law. i have ACA HID's so i have no need for my high beams but to flash etc. the reason i want to do this is because hid's don't like to be turned on/off continuosly and my fogs are hid
Attachment 47750415
86 is to switch
85 is to ground
awesome, do you have a part number for the relay?
wow that was a good read. looks similar to this at my local drys
http://www.frys.com/product/4191633?...H:MAIN_RSLT_PG
Old Dec 3, 2013 | 01:47 PM
PhysicsDude55's Avatar
PhysicsDude55
Either relay will work.
The 5 pin relays are DOUBLE THROW relays.
the 5th pin is the "normally closed" pin.
As you can see in the diagrams, the extra pin on the 5 pin relay is connected to the common pin when the coil is not energized.
You don't need the 5th pin for your purpose, but it doesn't hurt to have it, it will function in the same exact way as the 4 pin relay. Most standard relays you buy for automotive purposes have the 5th pin, usually labeled 87a.
tl;dr it will work
Old Dec 3, 2013 | 02:02 PM
mickey_7106
awesome. if i get the 5 pin relay 87a won't have to connected to anything since its spring loaded right?
tl;dr it will work
Old Dec 8, 2013 | 07:47 PM
PhysicsDude55
Correct. Just leave it disconnected and the relay will behave exactly the same as a 4 pin relay.
Old Jan 10, 2014 | 01:10 PM
mickey_7106
update.
I'm almost done with this but have one quick question. after a quick search i noticed that a few people used a 12 gauge power line. i used 18 gauge for all 4 wires. will the 18 gauge hurt "performance", that or melt the wire??
Old Jan 11, 2014 | 08:12 AM
dadaroo's Avatar
dadaroo
Since you like doing stuff yourself-
http://www.powerstream.com/Wire_Size.htm
Old Jan 13, 2014 | 08:20 PM
mickey_7106
i got it all hooked up but its not working like i want it too. Fog lights flicker when the high beams go off. any ideas?
i had pin
30 to power
85 to ground behind battery
86 to F12
87 to F6
BTW don't mind the ****** looking paint or plate lol
thanks
To Need help Choosing a relay
