C5 Headlight Upgrade - Issue noticed during install
Old Dec 6, 2013 | 06:43 PM
Pintoblades's Avatar
Pintoblades
Default C5 Headlight Upgrade - Issue noticed during install
Frank (forum member gnfan) is upgrading his pop up headlight gear on his C5. The original plastic gear is being upgraded to a brass gear.
Gear/shaft play was noticed when re-installing the new gear into
the housing. We are wondering if anyone had this problem,
and what have you done if anything, differing from the instructions. Did you just add washers to take up the play? Comments welcome on the Forum. Check out the video that shows how much play was present.
Old Dec 6, 2013 | 07:33 PM
Pintoblades
Comment from a Youtube subscriber in Canada. He is also full time mechanic. His comment:
harry
38 minutes ago:
They're supposed to have play
the headlamps hold it straight!
its to compensate for imperfections.
Not sure if he was serious or joking - Pintoblades
Old Dec 6, 2013 | 07:45 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
It seems to me that I used just 1 washer and put it all back together and have not had any issues at all for over 4 years now, I do believe that the arms will help keep everything lined up.
Old Dec 6, 2013 | 08:49 PM
Pintoblades
Thanks MrBill! We're just getting everyone's thoughts if they have some experience with them.
To C5 Headlight Upgrade - Issue noticed during install
