Forced Induction
Old Dec 17, 2013 | 06:51 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Originally Posted by Kreeess
Would there b any difference between a forged ls1 as to dropping in a bigger block ie ls2/lq9?
A lot of guys have used the LS2/LQ9 blocks stock with F/I and have had great results -
However in the LONG run in would/will be necessary to go with Forged internals - As stated right above^^^^^^
If you can get your hands ons a LS2 that would be an excellent way to go, just have to make sure it has the LS1/6 reluctor wheel in it and you will be set (for the timing triggering)
I also would stay with the Aluminum block over the Iron Block for weight purposes, they are proven to work great for F/I -
"BUT" if the added weight does not bother you then you can go Iron block as it will handle upwards of 25+ PSI of Boost whereas the LS2 I would not go above 23 PSI of Boost!
Thanks,Matt
Old Dec 17, 2013 | 11:19 AM
Mallett Z's Avatar
Mallett Z
2015 C5 of the Year Finalist
St. Jude Donor '07-'08-'09
Originally Posted by Mister Peebody
The main, and possibly, only difference between a V2 and V3 blower from Vortech is the method of oiling. The V2 or V3 designation tells nothing of blower size. The V2 uses the engine's oil so it requires tapping of the oil pan during install. The V3 houses its own oil, so it is totally independent from the engine oil and requires no tapping of the oil pan to install. Si trim, T trim, Ysi trim tell you the blowers air moving capability. There are many people, including myself, making north of 600rwhp with the little Si trim blower, but all of us are making more than 4# of boost.
Mine is neither a Si, T or Ysi trim V2 its a really old SC trim. When i talked to A&A about upgrading my kit, keeping my blower and running it at 8psi, They didn't think the blower was even capable of 8psi!
Old Dec 17, 2013 | 11:35 AM
Kreeess's Avatar
Kreeess
If you swap the motor, the lower end should be forged regardless of if it's a LS1, LS2, or LQ9. The bigger displacement motor still has weak internals so it has, basically the same vulnerabilities as the LS1. Forging means you have the motor built with internal parts, such as rods, pistons, and maybe even the crank that are forged vs cast. The forged parts are better, as they are built to hold more power than stock parts.
.. which leads me to my next question.... what is the difference with forging an ls1 block as to forging bigger displacement such as an ls2 what are the main pros and cons? I ask this because I want to try and figure out the most cost effective way on building a bottom end for boost.
Thanks,Matt
Matt, can you briefly explain the differences pros/cons of aluminum to iron block for boost? also would i benefit more with a forged bigger displacement rather than forging my current block?
Old Dec 17, 2013 | 01:00 PM
skydiven4fun's Avatar
skydiven4fun
St. Jude Donor '13-'14-'15
As many have stated, it's not very difficult to get north of 600 with the basic bolt ons, cam and either the SI or t trim kit from A&A or a kit from ECS, it was recommended to me that adding the meth was more for safety than to add more power, although it did give me more power as well, heck I'm still running stock heads and stock bottom end,my kit was installed on a well maintained LS1 with less than 70,000 miles, I also upgraded a lot of my drive train components.
At the very least install a good clutch when you do most of the above, or shortly afterwards, I know that one day I will have to go to a forged motor, and I plan on doing just that when the time comes, my car us a street ride, I don't beat the crap out of it all the time although I do blow her out when the opportunity presents itself, I'm running Hancook 305-30-19 tires on the rear, and that's my weak link, sure they break loose pretty easy, but with that being said and me not drag racing my car, it's the weak link and saves me from stressing my drive train, I know that keeps me from getting the best acceleration out of my car, but I'm cool with that, I will be replacing the rear tires before summer and will probably go with a stickier tire when I do, ill just be more carefull about how I drive my car.
One thing I did that I have really like is I installed a shift light on my A piller next to my gauges, my car makes peak power around 6700 rpm, but still make well over 600 at 5900, I set my shift light for 5900 it is so much easier to keep your eyes on the road and letting the shift light give you an indication of where your motor is at, these motors spin up pretty darn quick, especially if you break the rear loose any at all, anyway that works for me and keeps me from beating on my motor too hard, the only reason I would spin it up any higher is if I was racing her, and them I just reset the light to what I need.
I got the shift light after I lost traction one time and ran it up and bounced off the limiter, when that happened I seperated my MAF (too much pressure) now I run one of the girdles from A&A the later model MAF will separate under the right conditions.
Don't forget about the fuel system as well, every car us different and you may end up having to beef it up more than just what comes with the kit. (I had to myself) but after doing so and adjusting the tune she picked up a few more ponies.
Good luck and have fun, nothing like a boosted C-5
Old Dec 17, 2013 | 01:10 PM
Kreeess's Avatar
Kreeess
Originally Posted by skydiven4fun
As many have stated, it's not very difficult to get north of 600 with the basic bolt ons, cam and either the SI or t trim kit from A&A, it was recommended to me that adding the meth was more for safety than to add more power, although it did give me more power as well, heck I'm still running stock heads and stock bottom end,my kit was installed on a well maintained LS-1 with less than 70,000 miles, I also upgraded a lot of my drive train components.
You have to at the very least install a good clutch when you do most of the above, or at least shortly afterwards, I know that one day I will have to go to a forged motor, and I plan on doing just that when the time comes, but my car us a street ride, I don't beat the crap out of it all the time although I do blow her out when the opportunity presents itself, I'm running Hancook 305-30-19 tires on the rear, and that's my weak link, sure they break loose pretty easy, but with that being said and me not drag racing my car, it's the weak link and saves me from over stressing my drive train, I know that keeps me from getting the best acceleration out of my car, but I'm cool with that, I will be replacing the rear tires before summer and will probably go with a stickier tire when I do, ill just be more carefull about how I drive my car.
One other thing I did that I have really came to line is, I installed a shift light on my A piller next to my gauges, my car makes peak power around 6700 rpm, but still make well over 600 at 5900, I set my shift light for 5900 it is so much easier to keep your eyes on where your going and letting the shift light give you an indication of where your motor us at, these motors spin up pretty darn quick, especially if you loose traction, anyway that works for me and keeps me from beating on my motor too hard.
I got the shift light after I lost traction one time and ran it up and bounced off the limiter, when that happened I seperated my MAF (too much pressure) now I run one of the girdles from A&A (just in case)
thanks for this info, I drive my car pretty much how you drive yours, what numbers do you think I will produce on my ls1 block with 229/230 cam , ls6 intake,243 heads with dual springs, LT headears ORX pipe and exhaust?
I have seen very stock ls1s get over 600rwhp, I would imagine with my setup i can get over 600 safely?
Old Dec 17, 2013 | 01:20 PM
skydiven4fun
It would be a guess, so much depends on your tuner doing his job, but your set up should get you there, I'm running a pretty darn safe tune myself and still made well over 600 at 10lbs of boost.
Old Dec 17, 2013 | 01:36 PM
Kreeess's Avatar
Kreeess
thanks for the advice!
Old Dec 17, 2013 | 11:35 PM
Mister Peebody's Avatar
Mister Peebody
From: Ok! So you don't believe in conspiracies, but will you acknowledge the possibility of there being coordinated activities in secret places? Texas
Simply put; think of the motor as an air mover. The cam only allows the intake and exhaust valves to remain opened for a brief window in time, so to make power you need to get as much air as possible into and out of the cylinders as quickly as possible. FI gets the air in quicker. Larger displacement takes care of the "as much air as possible" part. Good headers and exhaust get the air out quicker. All things being equal, a larger displacement engine will move more air and make more power.
The biggest drawback of larger displacement, in general, is the weight of the rotating assembly. It eventually limits how fast you can spin the motor.
Again, this is an attempt at a very simple answer to his question, so experts please don't beat me up too bad.
Old Dec 18, 2013 | 01:06 AM
Kreeess's Avatar
Kreeess
I think it's a well explanation of how it works I get what your saying
Old Dec 18, 2013 | 07:08 AM
madmatt9471
Just saw your response - I gotta jam to work soon -
That is a loaded question and I will try to answer it the best I can and others can chime in -
But for starters the Cast Iron is usually much stronger than the Aluminum - Iron holds heat longer
But there are weight savings in the Aluminum as well as better heat displacement!
there are tons of threads on this comparison and it will take a little time to read some, here is a list:
https://www.google.com/#q=difference...aluminum+block
They both can and will make any amount of power you desire, but most go with the weight savings and durability of the Aluminum Blocks -
Cast Iron blocks can be punched out more than Aluminum ones too!
The list can go on - but I gotta jam!
Thanks,Matt
Old Dec 18, 2013 | 10:33 AM
Kreeess's Avatar
Kreeess
Thanks,Matt
thanks for this response def gon check out that reading.
