Front End Help Needed
Old Dec 15, 2013 | 05:32 PM
Corvette ED's Avatar
Corvette ED
From: Pottsville, PA. USA Home Of America's Oldest Brewery Yuengling
Default Front End Help Needed
2004 ZO6 with 65K miles when turning in either direction it feels like the car is in 4wd or it has posi chatter in the front.
Car has OEM Good Years on the front. What do you think is wrong?
Old Dec 15, 2013 | 10:01 PM
3sACROWD's Avatar
3sACROWD
Can you give us a little more information? At what speeds does this happen? Is this a new symptom or new to you car? Is it any left or right turn or just tight slow speed ones?
My Z06 will experience a "skipping" motion when performing tight left or right turns at slow speeds like when turning into a parking space. It is worse when driving in cold temps. It is normal and is due to a combination of tire width, alignment settings and tire compounds. The OEM tires are significantly affected by temperature. Temps below 50 make the GY Supercar compound hard.
If my above description doesn't apply to your case, have a competent mechanic get their hands on the front suspension and make sure everything looks ok. Bad ball joints can make your car feel the way you initially describe.
Old Dec 16, 2013 | 08:58 AM
Corvette ED
Car does the same skipping motion as yours when making tight left or right turns. Also the temps have been in the 20's
Old Dec 16, 2013 | 11:21 AM
dadaroo's Avatar
dadaroo
How old are your tires? Run flats are hard when they are new and get rock hard as time goes by. I assume you see no abnormal tire wear indicating an alignment issue.
Old Dec 23, 2013 | 12:35 PM
Corvette ED
Had the front tires replaced and it seems ok now.
To Front End Help Needed
