Just normal maintenance type stuff and most of the "common" issues such as belts, hoses, plugs, oil, water pump and normal C5 pattern problems Seriously considering an 01 that will be a frequent and basically daily driver and I prefer to most of my own maintenance and repairs. How tight is everything? Hard to get to items engine, interior etc? Thanks
Actually not bad at all and if you have some basic mechanical skills, you can do many things yourself. Plus this forum has a wealth of info on DIY projects on the C5.
I do oil and filter changes ... actually easier than most cars. Did plugs and wires. #7 plug is a bit of PTA but not too bad. When you run into a how to issue, somebody on here has the answer.
I'll be the first to say it - buy a FSM (Factory Service Manual) - about $200. You'll find everything you need there. But....... I have to be honest.... although I bought a FSM, I have yet to use it due to the knowledge here on CF!
Depends on your standard for "tight": the engine compartment is like a vast echoing cave compared to a lot of high-performance cars I've seen, especially anything turbocharged and/or mid-engine.
What it is, is low, as in some mainstream floor jacks won't fit. There are a few things like checking/changing diff/trans fluid that require getting all four wheels off the ground simultaneously, as you need the car to be both high and level. Depending on how big a deal that is to you, you may find yourself paying for jobs that are otherwise DIY-friendly.
+1 on this. Have worked on cars since I was 16, but I won't work on any modern car without the FSM. Have them for every car I own. Just too much good info in those big books.
C5 ( and C6 ) actually pretty good to work on, most stuff is easily reached. I do everything on my cars except tire mounting and alignments. Add the info and techniques found on the forum and you should be able to do just about anything. If you can get access to a lift then things just get easier.
From: It's true money can't buy happiness, but it is more comfortable crying in a Corvette than on a bicyc
St. Jude Donor '13
In all honesty it depends on what you're replacing. Some are easy straight forward and others are a bitch. A/C compressor, harmonic balancer, clutch, all qualify under bitch. Easy replaced on most cars, just no so easy on c5s.
FSM + CF + reasonable level of auto tech skill and experience = no issues for any DIY type job.
You will need a low profile jack and a lift is quite helpful, but not a requirement. Without either, you will never be able to get under the car to do anything.
Otherwise, C5's are well engineered and well built cars and serviceability is very good. If you enjoy working on cars, you will love it.
The hardest thing about working on mine is the intimidation factor. I come from an LT1 Camaro and I tore that thing down to the bare block. I look at my Corvette and even though its still just a plain old LS motor under the hood, I still cant get the "damn, I hope I dont screw anything up on my Vette" thoughts outta my head. I did plugs and wires, wasnt too bad. In April Ill be installing my A&A supercharger during my vacation, Ill probably be sweating bullets.
This car is easy to work on, with the proper tools, Manuals a must got my 3 books for 75.00 you can accomplish anything on this car.
I just did Crank/Rod bearings at the house on jack stands, no problem at all. your back will get soar from bending over the hood occasionally but you can reach across the engine compartment from one side.
From: Life moves pretty fast... if you don't stop and look around once in a while, you could miss it!
CI 6-8-9 Veteran
Having been a gear head for most of my 62 years (42 of which are with Vettes), compared to my 69 big block, its a dream to work on! It's all a matter of perspective. Zuti
Being in MN this is one of the easiest cars i have ever worked on due to the fact it doesnt have rust. And everything else is very open and easy. So straight forward with all the big stuff. The only thing i hate working on is any electrical stuff. But thats just cause im not good with it.
