lighting options
Old Dec 17, 2013 | 04:04 PM
cmark84's Avatar
cmark84
Default lighting options
So I noticed the inside of my vette is very dark. I replaced my rearview mirror with one that has a screen for when I engage reverse (backup camera).
I'm thinking of unique ideas of where to wire interior lighting to make it easier to see stuff in the vette.
Old Dec 17, 2013 | 04:36 PM
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
You can always do the east stuff first.
Order 7x 5 SMT 194 LED's to replace the stock little bulbs throughout the car.
2x trunk lights
2x footwells
1x glove box
See my web site... look under section " C5 LED Enhancements:"
www.ToqueZ06.com
I went all the way and replaced EVERY bulb in the car... , dash, switches with LED's
Old Dec 17, 2013 | 04:40 PM
Toque's Avatar
Toque
I have also added these 194 LED strips in the foot wells (not in pics above).
Easy plug in to the foot well light recepticles, and stick under the glove box/ under steering wheel.
I got mine at Auto Zone.
They REALLY brighten up the foot wells.
Old Dec 17, 2013 | 04:43 PM
cmark84's Avatar
cmark84
I guess I should've been more specific - I need better overhead lighting. I don't think the footwells will light up the interior enough to read anything on paper, but without actually having done the mod, I can't say 100% sure how bright it does get eye level.
Since I have a removable top, I don't see much options other than adding a small LED light bar above my rear view mirror.
Side note: I have done LED's in the trunk already.
Old Dec 19, 2013 | 03:00 PM
srs244's Avatar
srs244
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
they make a virtually clear (when off) led strip that you could always mount onto the windshield header above the rear view mirror and across from visor to visor. that would provide a great amount of lighting as you specify. obviously the best and most original looking would have been to add one of the electronic self dimming OEM mirrors that has map lighting built into it. adding LED bulbs to that fixture will give you more than enough light to do just about anything you would want to see in the pitch black. (in my 04 ce convertible i actually find the lighting too bright sometimes).
Old Dec 19, 2013 | 03:12 PM
cmark84's Avatar
cmark84
Ended up finding this on Amazon after a few minutes of searching:
Amazon.com: Compact LED Dome Convenience Light Auto Airplane Aircraft RV Boat Interior Cabin Cockpit LED Lighting: Automotive Amazon.com: Compact LED Dome Convenience Light Auto Airplane Aircraft RV Boat Interior Cabin Cockpit LED Lighting: Automotive
I might need to buy another, depending on if one is sufficient or not.
To lighting options
