Drivetrain Loss
Old Dec 18, 2013 | 07:37 PM
JaxEagle's Avatar
JaxEagle
Default Drivetrain Loss
Thought I'd share what I thought was a good article in terms of explaining drivetrain loss. I apologize if this has been posted before. Anyway, I have always used the percentage rule but after understanding a little bit more, I think it is basically false and futile to try to uplift RWHP to BHP. It is tempting to try to compare your car to a 505HP C6Z or a 556HP CTSV, etc., but I guess we need to just compare dyno numbers to dyno numbers. Heck, even those have plenty of variable making comparison not always black and white.
http://www.modified.com/tech/modp-10...s/viewall.html
Old Dec 18, 2013 | 09:06 PM
Interesting article. Thanks for the link.
Old Dec 18, 2013 | 09:27 PM
bobeast's Avatar
bobeast
A couple of points worth mentioning.
While there is no rule of thumb applicable across all vehicles, there is one (rough) that can be applied to each particular drive train combination. For example, an LS3 SAE of 430 probably has a specific percentage of loss for an Automatic and another for M6, give or take a few % points from car to car.
Where I think we go wrong is when we try to apply that percentage to mods. If, we, for example add ~25% HP, say 100HP, the drivetrain loss doesn't suddenly increase by 25%. As the article touches on, it is a nonlinear curve. That is to say. most of the added power makes it to the rear wheels, as drivetrain losses have already been factored in.
Old Dec 18, 2013 | 11:17 PM
JaxEagle's Avatar
JaxEagle
So this would say, in a sense, that our actual "percentage" of loss would decrease as power is added. So if a stock LS3 was 436 with 18% loss then possibly after mods, if properly measured, the 18% may become 14%.
Again, I basically just threw in the towel as far as trying to upwardly convert my rwhp to bhp. The only thing that would be good for is to make the number larger to wow someone more or to try to put it in terms of power numbers for cars that are presently being marketed.
Old Dec 19, 2013 | 12:32 AM
bobeast's Avatar
bobeast
Yeah. that sounds about right. To your original point, I think you are right. Its next to impossible to convert back and forth once you change any of the variables. Best to look only at dyno results, IMO.
Old Dec 19, 2013 | 08:31 AM
s'noJob's Avatar
s'noJob
The 15% "rule" is invalid?
What a drag ...
Old Dec 19, 2013 | 08:44 AM
sfc rick's Avatar
sfc rick
Can't you just make up the numbers to whatever you want? Let's say....with the high performance hood seal you can pick up 50hp. Then you can add another 15hp for the K&N filter....almost doubling the rwhp?
Old Dec 19, 2013 | 10:15 AM
JaxEagle's Avatar
JaxEagle
Yeah, what a drag. I prefer to tell people that my car has 638bhp like a ZR1.
To Drivetrain Loss
