Need ABS/EBCM help for 2001 Corvette
Old Dec 18, 2013 | 10:36 PM
xlr8nflorida's Avatar
xlr8nflorida
Default Need ABS/EBCM help for 2001 Corvette
My ABS light and Traction Control Lights are lit up on my 2001 C5.
I have the following cores in my parts collection. They all need the rebuild.
Does anyone know which of the 3 will fit my 2001 Corvette so that I can send it out for repair. Are they year specific?
Also, I realize you can solder and fix the module yourself but apparently there are services where you can fix it for $75.
I have only found this so far ABSFIXER and they want $150.
Any feedback would be appreciated. Thanks!
I think this part new at dealer is like $1600.
Old Dec 18, 2013 | 10:41 PM
brucemac64's Avatar
brucemac64
Send to abs fixer...I did a year ago everything works great and light out. I always suggest getting the extra set of screws for the module too....just n case.
Good luck!!
Old Dec 19, 2013 | 04:42 PM
brucemac64's Avatar
brucemac64
You can call absfixer and they can tell you which is the right one. Also they will probably buy your other ones!!! They need cores.
Old Dec 19, 2013 | 04:59 PM
vettestream's Avatar
vettestream
I would check your grounds first. If it is definitely the module I would just call ABSfixer and ask them which one is correct for your use.
Old Dec 19, 2013 | 10:02 PM
corvette77's Avatar
corvette77
Have you pulled your codes to find out why they are lit up first?
Old Dec 20, 2013 | 06:28 AM
Cybermind's Avatar
Cybermind
Another option is Modulemaster.com. I purchased a complete rebuilt unit from them for $250.00 (no core charge). This allowed me to keep my original as a spare. They were very helpful and provided excellent service. I believe their rebuild service is $150. Give them a call. They can probably tell you which one is right for your car.
To Need ABS/EBCM help for 2001 Corvette
