A4 jumps during down shift
Old Dec 22, 2013 | 10:55 AM
chataylo's Avatar
chataylo
Default A4 jumps during down shift
I am a new member and could use your knowledge with my problem. First of all I live in the northeast mountains of Tennessee and have not found a tuner in the area. I bought 98 vette with blown engine. Rebuilt engine to stock except for cam (EDEL 2215). Was not told of A4 problems. Had A4 rebuilt and on my way home noticed that when I coast from 60mph down to automatic 3rd gear down shift (between 52mph and 48mph) it started jumping, jerking. It does it in all down shifts while coasting, but not as bad. I have to hold a lot of pressure on brake to engage transmission from park. I should also mention that idle speed is 850rpm. Went back to A4 rebuild shop and was told throttle position sensor was bad. Replaced tps with no change. Not sure if rebuilder can remedy this problem. Would like to hear your suggestions.
Old Dec 22, 2013 | 01:01 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Sounds like a couple of possibilities:
(1) Cable linkage on side of tranny not set correctly
(2) Module on side of tranny may be loose
(3) at this point it could be quite a few things all the way down to error of tranny shop - but it was "NOT" the TPS by far!
Can you pull the codes from the Vette and let us know if there are any?
How to pull codes on C5 DIC:
Codes:
http://www.stengel.net/diccodes.htm
Thanks,Matt
Old Dec 22, 2013 | 03:14 PM
Phanni's Avatar
Phanni
Give John Llewellyn a call.
He's in Knoxville.
He deals exclusively with C-5s
865-604-0497
Old Dec 22, 2013 | 06:13 PM
chataylo's Avatar
chataylo
Retreiving & Clearing Codes on a 1997-2004 C5 Corvette - YouTube
Codes:
Thanks,Matt
I had cleared codes when TPS was installed. Plan on trip back to tranny shop tomorrow and will let you know what codes come up when I return. Thanks
Old Dec 22, 2013 | 06:17 PM
chataylo's Avatar
chataylo
He's in Knoxville.
865-604-0497
Thank you and I will call him.
Old Dec 22, 2013 | 11:46 PM
madmatt9471
Right on!
Thanks,Matt
Old Dec 23, 2013 | 03:40 PM
chataylo's Avatar
chataylo
Right on!
Thanks,Matt
Called tranny shop to set appointment to return vette . I then drove it around a little and checked codes.
BO RFA U1016 H C
U1064 H C
U1096 H C
Let me Know if you come up with anything.
Charlie
Old Dec 23, 2013 | 11:49 PM
madmatt9471
BO RFA U1016 H C
U1064 H C
U1096 H C
Charlie
B0-RFA - Remote Function Actuation
U1016 Loss of Communication with PCM
U1064 Loss of Communication with BCM
U1096 Loss of Communication with IPC
Nothing related to the tranny!
Thanks,Matt
Old Dec 26, 2013 | 09:43 AM
chataylo's Avatar
chataylo
He's in Knoxville.
865-604-0497
Is this a good #? No John there!
Charlie
Old Dec 26, 2013 | 09:51 AM
chataylo's Avatar
chataylo
Charlie
Update on John: He passed away two years ago.
To A4 jumps during down shift
