Checking the ac acuator? Please help
Old Dec 23, 2013 | 10:47 PM
Johnljr's Avatar
Johnljr
Default Checking the ac acuator? Please help
So i got acode for the HVAC, 0441 and pulled the actuator, opened it up and the gears are fine, plugged it in and when i checked the codes again the actuator moved all the way from one side to the other fine, then when i started the car and turned the ac on the indicator would only move from the middle mark to one side but doesnt go all the way to the the other side, does that mean its bad or is it a different problem?
Thank you
