hatch open light
Old Dec 25, 2013 | 10:08 AM
cprbycps's Avatar
cprbycps
1st Gear
Default hatch open light
My c5 will. Display the "open hatch" indicator and the only way I can get it to turn off into slam the hatch lid. Any ideas?
Old Dec 25, 2013 | 10:29 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Sounds like the contact in the latch is needing to be adjusted or re-aligned!
It is very possible is is sticky and needs to be cleaned! You are gonna have to pull the panel around the latch and check it out!
Keep us posted on the findings and pics too of any findings! Just in case someone else should have this problem!
Thanks,Matt
Old Dec 25, 2013 | 10:39 AM
Phanni's Avatar
Phanni
Believe it or not the C-5 coupe is pretty air tight. If you lower the hatch with the doors closed and the windows up, the hatch will quite often not close completely enough for the car to sense it's latched.
Try closing it with the windows down and you'll see it works better. Save that, if you close the hatch then press down on both sides of it will also fit tighter.
The next time you get that message, get out of the car and press down on the hatch and see if it seals better and shuts off the 'alarm'.
Old Dec 25, 2013 | 10:49 AM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
Most of the time after I close my hatch I have to push down on the left and right side to make sure it is closed, If I don't I will get the hatch open light. On mine it looks closed, But it isn't.
To hatch open light
