Which fuel do you run?
Old Dec 26, 2013 | 09:14 AM
HotRodMomma's Avatar
HotRodMomma
Default Which fuel do you run?
I know people that run regular old unleaded, mid grade and then premium.
Manual says you "can" run lower ocatane.....
What do you run in yours?
Old Dec 26, 2013 | 09:18 AM
Maxx_Z06's Avatar
Maxx_Z06
C5 COTM Coordinator
Always and only PREMIUM. I'd rather push my car to the next gas station than to run anything else.
Old Dec 26, 2013 | 09:22 AM
amlarson2001's Avatar
amlarson2001
our bp's around here have 93 so i go there. they are the only regular station around with 93.
Old Dec 26, 2013 | 09:48 AM
coia96vette's Avatar
coia96vette
Only 93 octane for my 04.
Old Dec 26, 2013 | 09:56 AM
rick7913's Avatar
rick7913
Only 93 octane!
Old Dec 26, 2013 | 10:00 AM
Yellogixxer's Avatar
Yellogixxer
93 octane, preferably from Sunoco.
stevegray04's Avatar
stevegray04
St. Jude Donor '14
Nothing but 93 octane and a bottle of Techron or Seafoam every few thousand miles.
Old Dec 26, 2013 | 10:11 AM
dannyman's Avatar
dannyman
Maxx;
Perfectly stated!
In my case I have 94 octane available. It's all she drinks!
Dan
Old Dec 26, 2013 | 10:19 AM
c4cruiser's Avatar
c4cruiser
Originally Posted by dannyman
Maxx;
Perfectly stated!
Dan
I found the 94 octane and ethanol-free stuff on a trip into B.C. last August, Sure seemed to make my supercharged '02 run better. But the $1.56 per liter made my Chevron card cry....
But as far as running a lower grade like 87 or 89 octane, it's doable and the ECM will make changes depending on what it see from the knock sensor and the O2 sensors. Usually it will a retarding of the timing and maybe some changes in the fuel map.
I think the idea of "allowing" a lower grade is so that if you wind up somewhere needing gas and 87 is all that's available, the car will run on it. Just don't hammer on the car; very easy foot on the gas and don't load up the engine.
Old Dec 26, 2013 | 10:27 AM
JR-01's Avatar
JR-01
When I go on long trips when I rarely get over 65 mph and cruise AT 2000 RPM, I run mid grade, 89 octane. I am getting 27 mpg and since it does not knock there really is no need for higher octane. The only time you need premium is when you are running it hard. Premium is a waste for driving around town and cruising at 60 mph, lower grades will not hurt your car. Some folks are a little fanatical when it comes to gas. But it's there choice.
Some engines for which premium gasoline is recommended can run on regular without problems. That's because the engine's knock-sensor system detects the presence of uncontrolled burning in the chambers. When it does, the engine's computer-control system retards engine timing, eliminating the knock but slightly reducing power. If you don't mind giving up some performance, you can run these engines on less-expensive regular gasoline. To check whether your engine is capable of running on regular gas, read your owner's manual or ask your dealership's service department.
Old Dec 26, 2013 | 10:42 AM
CQRT's Avatar
CQRT
Originally Posted by HotRodMomma
Manual says you "can" run lower octane.....
Why would you ?
Not worth saving a few cents, especially on an older engine IMO.
There will always be those who say it's all a scam by Big Oil to make money, but there's definitely a difference in performance and fuel mileage.
Old Dec 26, 2013 | 10:44 AM
blackmachdown's Avatar
blackmachdown
E85...mmmm 105 octane
Old Dec 26, 2013 | 10:45 AM
Chilliwack vettes's Avatar
Chilliwack vettes
Chevron 94 for me up here. When I had my '88, I ran 87 quite a bit. Then I tried 94 for a tank and it made a huge difference - smoother and more power. I don't see a point to save a few dollars on fuel when I'm trying to get the car to perform its best.
bj1k's Avatar
bj1k
I alternate , regular then premium so it is mixed in the tank at all times . Also add Techron . I never run the car hard and it runs fine on that mixture.
Old Dec 26, 2013 | 10:49 AM
JR-01's Avatar
JR-01
Originally Posted by CQRT
Why would you ?
Not worth saving a few sense, especially on an older engine IMO.
Why not? It doesn't hurt anything. I got the same gas mileage with 93 and 89. The only time you really need premium is when you get on it. Lower grades will not hurt the engine and if you are going to drive it hard fill it with 93. Around town and cruising at 55, premium is a waste, it's not better gas, it just has more anti knock compounds. Too much anti knock compounds will actually reduce performance.
Old Dec 26, 2013 | 11:14 AM
daddoe's Avatar
daddoe
Rocket fuel....anything else is for sissies.
Old Dec 26, 2013 | 11:29 AM
jrose7004's Avatar
jrose7004
I run premium 91 octane 100% gasoline. Around here the highest octane you can get is 91.
To Which fuel do you run?
Old Dec 26, 2013 | 11:35 AM
f6john's Avatar
f6john
Since everything else I own runs on 87, I accidentally put some 87 in the Vette. It ran but would ping on acceleration and just was not fun. I got some 93 in it as soon as I could make room! If I can't afford the difference from mid grade to premium, I'll just park it.
Old Dec 26, 2013 | 11:51 AM
FormerlyFiero's Avatar
FormerlyFiero
Oldtimer
Shell premium is ethanol free in Oregon, it's all she gets. Besides, I have a Shell card (Which I pay off every month).
Old Dec 26, 2013 | 01:10 PM
DevilDog II's Avatar
DevilDog II
Veteran: Marine Corps
Oldtimer
Mobil premium, which is 93 octane here.
