battery tender , dumb question
Old Jan 5, 2014 | 09:16 AM
bigcypress's Avatar
bigcypress
Default battery tender , dumb question
my first dumb question.......this year . my sons 97 honda vcr sets in the driveway with a battery tender on it . question is , can i unplug battery tender and leave it connected to battery for a day or so without doing damage to battery or tender . worse : it's supposed to get 18 below zero and i don't know what anti freeze is set to so want to hook up light bulb instead to ,hopefully , avoid a frozen block or radiator . . be kind i'm old . . .peace...........ps. alternative is to put honda in garage and a vette outside . this suggestion has not gone over well with my wife , the owner of the vettes .
Old Jan 5, 2014 | 09:32 AM
dadaroo's Avatar
dadaroo
The tender is connected one of two ways. Either with two battery clips which you just unclip or the tender is connected using "lug" connections which have to be unbolted. In both cases you will notice there is a plug in the wiring that can be disconnected to allow the use of the clips or lug connections. I would just use that plug to disconnect the tender so it does not get rained on.
I don't know if leaving the tender connected but unplugged will provide some battery drain or not. What I recommend is what I would do.
Old Jan 5, 2014 | 12:00 PM
jdvann's Avatar
jdvann
I would use a multi head cord or splitter and plug in both. Jim
Old Jan 5, 2014 | 12:32 PM
dadaroo's Avatar
dadaroo
Good idea, the tender should not be drawing enough current to be an issue in parallel with a light bulb. Could also test the coolant to see how low a temp it can support. If you don't have a tester they are cheap or just drive his car to an auto store and they should be able to test.
Old Jan 5, 2014 | 12:45 PM
c4cruiser's Avatar
c4cruiser
This. The battery tender and using something like a 150W heat lamp won't be a big current draw. But I would use an extension cord with 14 gauge wire; that way the cord can be up to 50' long and will handle the current draw. And having the battery fully charged will keep the battery in good condition and safe from freezing.
If his car has a 50-50 mix of antifreeze and water, that will provide protection down to -37 degrees F. But it would be a good idea to get a tester (all auto parts stores have them for just $5-$6) and make sure the coolant is at least below the anticipated temps.
Old Jan 5, 2014 | 06:19 PM
ALLEGRO's Avatar
ALLEGRO
Do both, be on the safe side for certain.
Old Jan 5, 2014 | 06:41 PM
65GGvert's Avatar
65GGvert
vcr=CRV?
Old Jan 6, 2014 | 07:16 AM
bigcypress's Avatar
bigcypress
thanks for your COURTEOUS replies as i expected to be roasted .
Old Jan 6, 2014 | 07:24 AM
sfc rick's Avatar
sfc rick
Originally Posted by 65GGvert
vcr=CRV?
They both mean about the same thing.
To battery tender , dumb question
