Is it possible to replace the auto HVAC Controller?
Old Jan 7, 2014 | 06:03 PM
Torque Obsessed's Avatar
Torque Obsessed
Default Is it possible to replace the auto HVAC Controller?
I hate the automatic HVAC controls in my '02 Z06. It works, and it's not dim. It's just a pain in the butt. If it turn it Off, the next time I try to turn it on, it will default to a different setting. I can't seem to get it to just turn on the dash vent fans without triggering the A/C or changing over to the defrost/floor setting. So I find myself driving down the road pressing Mode over and over again trying to get back to what it was set to before I turned it Off. Then I have to turn A/C off as well. This is frustrating, and dangerous because I'm distracted fighting with my climate controls while moving.
Am I just too stupid to use this? I don't want auto anything. I just want a normal HVAC controller with ***** and buttons that work normally. I rented an old Impala a year ago and was like, "OMG look! A normal climate control system that just does what you set it to! Why can't my Vette have this?" Can I retrofit a normal HVAC controller (non-auto) into my C5? Is there a writeup for this?
Apologies if there are already threads on this... I've searched here and Googled for this, plus checked the stickies but didn't see anything.
Old Jan 7, 2014 | 06:10 PM
coia96vette's Avatar
coia96vette
I know on my 04 coupe if I sent the HVAC to upper and lower vents and turn the auto function off, it will stay that way until I turn the auto function back on again. I to got tried of it turning the ac on when not needed.
Old Jan 7, 2014 | 06:12 PM
Torque Obsessed
Hmm. Maybe mine is broken? My auto function stays off, but if I have it set to upper/lower vents and turn it Off, I can't figure out how to turn it back on again without changing settings. How do you turn yours back On? Press up on the fan toggle? This could be user error on my part.
Old Jan 7, 2014 | 08:22 PM
If I recally correctly, that's the way mine works. I'll have to check to be sure.
Old Jan 7, 2014 | 08:34 PM
coia96vette
I just push the auto button again and it returns to the same settings that where set already.
Old Jan 7, 2014 | 09:13 PM
65GGvert's Avatar
65GGvert
Try setting it where you want it and hold down the memory button on the door for a few seconds. Next time it's wrong, just press the same button momentarily. The whole idea of the auto function is to set the temp you want and let it move the fan and functions to match conditions.
Old Jan 7, 2014 | 09:31 PM
MSG C5's Avatar
MSG C5
2018 C5 of Year Finalist
I live in Florida and I drive a convertible. My biggest fear is that the unit won't work the 3 times I use it every year.
Old Jan 7, 2014 | 09:35 PM
ZeroToSixty's Avatar
ZeroToSixty
Mine is dimming,.............and the AC light blinks and won't stay on.
I am not sure if this is a larger problem. All I care about now is whether the heat works and keeps the front windshield clear.
What is the best way to approach this issue and test whether the AC is working properly ?
Old Jan 7, 2014 | 10:31 PM
TEXHAWK0's Avatar
TEXHAWK0
The dim display can be fixed, normally by re-soldering the display resistors on the power board.
If the AC light is blinking, it could be because the outside temp is to low (below 38 deg), or the system could be low on Freon.
Old Jan 8, 2014 | 08:34 AM
ZeroToSixty
OH I assure you it is below 38 degrees,...........so the AC system has a default where it will not engage below that temperature ?
I just assumed it would work on defrost with the heat on to aid in clearing ice on the front windshield.
Old Jan 8, 2014 | 08:51 AM
Fcar 98's Avatar
Fcar 98
I have one of those early cars with the 3 ****, Love it. the less electronics the better.
Old Jan 8, 2014 | 01:24 PM
corvettebob1's Avatar
corvettebob1
Yep, it's explained in the owners manual.
Old Jan 8, 2014 | 01:29 PM
Corvette_Ed's Avatar
Corvette_Ed
With all of the problems people have with the electronic controls I'm glad that mine has the manual controls.
Old Jan 8, 2014 | 03:45 PM
darkstar.c5's Avatar
darkstar.c5
the a/c runs when the defroster is on.. so if you press the a/c button in that mode to turn it off... the light flash and the a/c will not disengage.
Old Jan 9, 2014 | 01:00 PM
fixvet's Avatar
fixvet
RTFOM
Old Jan 9, 2014 | 02:05 PM
ram01's Avatar
ram01
i have a 2001 vert.My auto works fine never had problem
Old Feb 3, 2014 | 06:59 PM
psint's Avatar
psint
The A/C is supposed to run when the defrosters are on. The purpose is to remove moisture from the air. Most cars do that. Your Air Conditioner evaporator acts as a dehumidifier.
Old Feb 4, 2014 | 04:48 PM
aerovette99's Avatar
aerovette99
Ask the guy at www.c5led.com. He knows those units
To Is it possible to replace the auto HVAC Controller?
