I have ran into another problem. My heater core let go completely the other day. I made it back to the house but the car kept saying low voltage then it wouldn't start again. So I checked the battery it had 11 volts , I charged it the car started . I turned it off and it wouldn't start again so I got a new battery same thing started once then not again. The car is a 99 c5 manual . Any ideals out there .
Check all of your grounds and clean them . The cold weather could be causing the weak connections.
There are no codes but when I put the key in and turn to the run position I can hear the fuel pump prime up but nothing when you turn to crank nothing happens . Now nothing is coming on the Dash anymore . It won't say corvette or show the miles or anything . The passenger side floor board was full of coolant . Could one of the computers or the fuses box be wet or worse.
Hey guys . We'll I found out why my car would not start . The computer is done . So I'm looking for another one. The numbers on it are serv.No. 98381399. - * 87cyshm191650415*
My car is a 99 c5 manual . Anyone out there have one please let me know my email is metalheadstunna@yahoo.com
I found a blown fuse so I replaced it and the smoke came rolling out of the silver box right beside the fuse block. So I took it out and opened it up and it has a burn spot bad . I hope I can find one cheaper than 800 buck.
Thanks for your help . I started removing the seat and carpets tonight yeah the coolant is in everything it's going to take some time to clean all of it up . Pulled the batt already I check eBay for another part I found a few for 800 and some for 250 so I guess I need to check around some more . Once again thanks
I wouldn't be surprised if it is my car the guy in AL got the part for bc the guy I bought the car from had the car in AL getting a BCM for the car. And the one I took out is a used part.
Did you just replace the fuse and try it? I read where they recommended you take everything apart and clean dry first but your response came after the fuse change??
Never mess with liquid/power, hopefully you didn't fry something else in the process, clean everything and let it all dry out, theres a spray thats suppose to clean ands dry out electrical wiring and boards, can't remember the name tho.
Good luck with the repairs it sucks they would put computers under the heater cores.
I have an 85 when I turn the key all the way to start the car the security light flashes and no dash lights car cranks but does not start. can anyone helpppppp
