Tire Question - Sizes
Old Jan 8, 2014 | 02:31 PM
kgie1217's Avatar
kgie1217
St. Jude Donor '14
Default Tire Question - Sizes
I'm about to buy some new wheels. Sizes will be 18" x 8.5" and 19" x 10". Recommended tire sizes are 275/35-18 and 285/35-19 respectively. Just wondering what everyone else is running on similar size wheels. Any info would greatly be appreciated.
Old Jan 8, 2014 | 02:35 PM
Sinister-one's Avatar
Sinister-one
18 x 9.5's w/ 275 35 18's in front and 19 x 11's with 325 30 19's out back.
Love the way that FAT tire fills out the *** end !!
Old Jan 8, 2014 | 05:04 PM
racebum's Avatar
racebum
275 35 18 is too wide for 18x18.5
that uses 245 40 18 if you want to match the rear
also is a hair taller than stock so you will probably be off 1-2mph on the speedo
typically people run 305 30 19 on 19x11 and 275 35 18 on 18x9.5
or
295 30 19 and 265 35 18 on 19x10.5 and 18x9
Old Jan 8, 2014 | 06:17 PM
Zr-1Mike00's Avatar
Zr-1Mike00
Fronts: 18x9.5 +57mm offset with 275/35/18's
Rears: 19x11 +64mm offset with 305/30/19's
The offsets are factory sizes so they sit flush.
Old Jan 8, 2014 | 08:46 PM
6speedsteve's Avatar
6speedsteve
I have on order tires for 19x9 & 19x10 and will be running 255/35/19 & 285/35/19 Nitto Invo's, the front sidewall should be even with the rim & the rear should have about 3/16" bulge.
Old Jan 9, 2014 | 10:05 AM
kgie1217's Avatar
kgie1217
St. Jude Donor '14
or
Why would the 275/35-18 be too wide? Seems other's are running that size upfront.
Old Jan 9, 2014 | 11:25 PM
imgn tht's Avatar
imgn tht
St. Jude Donor '13, '15
The tire itself if not too wide for the car. What he is stating is that the tire is too wide for the rim size you chose. A 275/35/18 is sized to fit rims 9"-11" wide. The people running them have 18 x 9.5 rim up front.
Old Jan 10, 2014 | 04:41 PM
PRE-Z06's Avatar
PRE-Z06
That tire size is the stock C6Z width, but the rim is the narrower base C6 size.
Old Jan 10, 2014 | 05:17 PM
Black 02's Avatar
Black 02
It'll also make your car look weird because the front tires will be ballooning of the wheels in that size while the rears will look correct.
To Tire Question - Sizes
